Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
VRRP Administration Guide
PDF
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
Protocol Description
Introduction
Configuring VRRP
Introduction
VRRP Topology
Configuration Guidelines
Default Configuration Values
Create VRRP Instance Over an Interface
Configure Additional Associated IP Addresses to a VRRP Instance
Configure VRRP Priority
Enable Preempt Mode
Configure Authentication Password for VRRP Tickets
Configure VRRP Advertisement Interval
Configure VRRP (Linux Example)
CLI Command Modes
The following table lists the configuration modes used in this document with their access and exit methods.
Command Mode
Access Method
Prompt
Exit Method
User EXEC
Access SEFOS from Oracle ILOM with read-only rights (privilege level 1).
SEFOS>
Use logout or exit to return to the Oracle ILOM prompt.
Privileged EXEC
Access SEFOS from Oracle ILOM with full administrative rights (privilege level 15).
SEFOS#
Use the logout or exit command to return to the Oracle ILOM prompt.
Global Configuration
From User EXEC mode, use the enable command.
SEFOS(config)#
Use the end command to return to Privileged EXEC mode.
Interface Configuration
From Global Configuration mode, use the interface interface-type interface-id command.
SEFOS(config-if)#
Use the exit command to return to Global Configuration mode, or use the end command to return to Privileged EXEC mode.
VRRP Router Configuration
From Global Configuration mode, use the router VRRP command.
SEFOS(config-vlan)#
VRRP Interface Configuration
From VRRP Router Configuration mode, use the command interface vlan vlan-id command.
SEFOS(config-vrrp-if)#
