Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
RIPng Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
RIPng Overview
Protocol Description
Configuring the RIPng Topology Example
Configure SEFOS1
Configure SEFOS2
Configure SEFOS3
General Configurations
Configuring IPv6 RIPng
Enable RIPng
Enable and Configure RIPng on Desired IPv6 Interfaces
Configuring Redistribution
Redistribution Overview
Disable Redistribution
Disable the split-horizon Option
Configuring the Debug Level for RIPng
Enable Debugging
Disable RIPng Debugging
RIPng Overview
This section describes the RIPng protocol and how to configure the example topology:
