CLI Command Modes
The following table lists the configuration modes used in this document with their
access and exit methods.
User EXEC |
Access SEFOS from Oracle ILOM
with read-only rights (privilege level 1). |
SEFOS> |
Use logout or exit to return to
the Oracle ILOM prompt. |
Privileged EXEC |
Access SEFOS from Oracle ILOM with full administrative rights (privilege
level 15). |
SEFOS# |
Use the logout or exit command to return to the Oracle
ILOM prompt. |
Global Configuration |
From Privileged EXEC mode, use the configure terminal command. |
SEFOS(config)# |
Use the end
command to return to Privileged EXEC mode. |
Interface Configuration |
From Global Configuration mode, use the
interface interface-type interface-id command. |
SEFOS(config-if)# |
Use the exit command to return to Global Configuration mode, or
use the end command to return to Privileged EXEC mode. |
