Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
RIPng Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
RIPng Overview
Protocol Description
Configuring the RIPng Topology Example
Configure SEFOS1
Configure SEFOS2
Configure SEFOS3
General Configurations
Configuring IPv6 RIPng
Enable RIPng
Enable and Configure RIPng on Desired IPv6 Interfaces
Configuring Redistribution
Redistribution Overview
Disable Redistribution
Disable the split-horizon Option
Configuring the Debug Level for RIPng
Enable Debugging
Disable RIPng Debugging
By default, the split-horizon option with poison reverse is enabled on all RIPng interfaces.
  1. On SEFOS1, enter the configuration mode for the interface and disable split-horizon.
    SEFOS 1 SEFOS# configure terminal
    SEFOS 1 SEFOS(config)# interface vlan 40
    SEFOS 1 SEFOS(config-if)# no ipv6 split-horizon
    SEFOS 1 SEFOS(config-if)# end
    SEFOS 1 SEFOS#
  2. Review the configuration information.
    SEFOS 1 SEFOS# show ipv6 rip
    RIP  port 521, multicast-group ff02::9,Maximum paths is 16
    Updates every 30 seconds; expire after 180
    Garbage Collect after  120 seconds
    Split Horizon is off;
    Interface:
    vlan50
    vlan40
    vlan30
    Redistribution:
     Connected,Routes  Redistribution is enabled.
