Skip Navigation Links
Exit Print View
Sun Ethernet Fabric Operating System
RIPng Administration Guide
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Acronyms and Abbreviations
CLI Command Modes
Feedback
Support and Accessibility
RIPng Overview
Protocol Description
Configuring the RIPng Topology Example
Configure SEFOS1
Configure SEFOS2
Configure SEFOS3
General Configurations
Configuring IPv6 RIPng
Enable RIPng
Enable and Configure RIPng on Desired IPv6 Interfaces
Configuring Redistribution
Redistribution Overview
Disable Redistribution
Disable the split-horizon Option
Configuring the Debug Level for RIPng
Enable Debugging
Disable RIPng Debugging
The following example disables the redistribution of directly connected routes (5555::0) on SEFOS1. With redistribution disabled, the route to 5555::0 is not visible on switches SEFOS2 and SEFOS3.
  1. On SEFOS2, review the route information before disabling redistribution.
    SEFOS 2 SEFOS# show ipv6 route
    IPv6 Routing Table  -  6 entries
    Codes : C - Connected, S - Static
            O - OSPF, R - RIP, B - BGP
    C   1111::/112   [1/1]
            via ::, vlan10
    R   2222::/112   [3/120]
            via fe80::221:28ff:fe56:d7a9, vlan40
    R   3333::/112   [2/120]
    C   4444::/112   [1/1]
            via ::, vlan40
    R   5555::/112   [2/120]
    C   6666::/112   [1/1]
            via ::, vlan10
  2. On SEFOS3, review the route information before disabling redistribution.
    SEFOS 3 SEFOS# show ipv6 route
    IPv6 Routing Table  -  7 entries
    R   1111::/112   [3/120]
            via fe80::221:28ff:fe56:d7a9, vlan30
    C   2222::/112   [1/1]
            via ::, vlan20
    C   3333::/112   [1/1]
            via ::, vlan30
    R   4444::/112   [2/120]
    R   6666::/112   [3/120]
  3. Disable the route redistribution on SEFOS1.
    SEFOS 1 SEFOS# configure terminal
    SEFOS 1 SEFOS(config)# ipv6 route rip
    SEFOS 1 SEFOS(config-router)# no redistribute connected
    SEFOS 1 SEFOS(config-router)# exit
  4. On SEFOS2, review the route information after disabling redistribution.
    Note that 5555::/112 [2/120] is missing from the output.
    IPv6 Routing Table  -  5 entries
    C   1111::/112   [1/1]
            via ::, vlan10
    R   3333::/112   [3/120]
    C   4444::/112   [1/1]
            via ::, vlan40
    C   6666::/112   [1/1]
            via ::, vlan10
  5. On SEFOS3, review the route information after disabling redistribution.
    C   2222::/112   [1/1]
            via ::, vlan20
    C   3333::/112   [1/1]
            via ::, vlan30
    R   4444::/112   [3/120]
