对于更改属性可能会中断当前用户会话的目标,配置包括提交待定更改以使之生效。
例如,更改 Oracle ILOM 中 SP 的 IP 网络设置将导致中断当前用户会话。因此,您将需要提交对 IP 属性进行的所有更改,然后更改才能在 Oracle ILOM 中生效。
以下是一个提交对 IP 属性的更改的过程示例:
查看当前网络设置。
-> show /SP/network
/SP/network
Targets:
interconnect
ipv6
test
Properties:
commitpending = (Cannot show property)
dhcp_clientid = none
dhcp_server_ip = none
ipaddress = 192.0.2.22
ipdiscovery = static
ipgateway = 192.0.2.1
ipnetmask = 10.255.255.0
macaddress = 00:28:25:E7:18:0C
managementport = MGMT
outofbandmacaddress = 00:28:25:E7:18:0C
pendingipaddress = 192.0.2.22
pendingipdiscovery = static
pendingipgateway = 192.0.2.1
pendingipnetmask = 10.255.255.0
pendingmanagementport = MGMT
sidebandmacaddress = 00:28:25:E7:18:0D
state = enabled
Commands:
cd
set
show
要更改设置,请首先输入新的(待定)信息。
->set /SP/network pendingipdiscovery=static pendingipaddress= nnn.nn.nn.nn pendingipgateway=nnn.nn.nn.nn pendingipnetmask=nnn.nn.nn.nn
然后,在确认新的设置正确后,提交新设置,使其立即生效:
-> set /SP/network commitpending=true
