| Skip Navigation Links | |
| Exit Print View | |
Oracle SuperCluster M6-32 Zones With Oracle Database on Database Domains Configuration Guide |
Planning to Set Up Zones on Database Domains
Extended Configuration PDomain Overview
Understanding Extended Configuration PDomains
Understanding Base Configuration PDomains
Understanding LDom Configurations for Extended Configuration PDomains
Understanding LDom Configurations for Base Configuration PDomains
Determining the Cores Available for LDoms and Zones
Cores Available for Domains and Zones
Zones and Cluster Planning for Database Domains
Guidelines for Planning the Number of Zones and Clusters
Guidelines for Planning the Storage Server Disk Group Layout
Understanding an Example Scenario
Recording Your Existing and Planned Configuration Information
Recording Your Zone Configuration Information
Database Domain 1 Zone Configuration Information
Database Domain 2 Zone Configuration Information
Database Domain 3 Zone Configuration Information
Database Domain 4 Zone Configuration Information
Recording Your Storage Server Disk Group Layout
Preparing to Configure Zones on Database Domains
Determine the Repository Location
Install or Update Packages From the Remote Repository
Install or Update Files From the Local Repository
Verify Configuration Tool Installation
Creating Configuration Files (OEDA)
Verify Storage Server Disk Space for Additional Zones
Locate the Necessary Files to Set Up Zones
Import the Most Recent OEDA Configuration File
Review Existing Configuration Information
Review the Information in the Identify Compute Node Operating System Page
Review the Information in the Management and Private Networks Page
Complete the Define Clusters Page
Set Zone Default Configurations
Complete the Cluster Review and Edit SCAN, Client, VIP, and Optional Backup Networks Page
Verify Remaining Configuration Information
Generate the Configuration Files
Creating the Template Zone on Each Database Domain
Create a Template Zone on a Database Domain
Delete a Template Zone From a Database Domain
Determining if Additional VNETs Are Needed for a Database Domain
Determine if Additional VNETs Are Needed (Using Specific LDom Information)
Determine if Additional VNETs Are Needed (Using Software Commands)
Set Up Public Key Authentication for ZFS Storage Controllers
Creating Additional Links on the IB Storage Network for Zones
Create Additional Links on the IB Storage Network for Zones
Use this table to record the following information for each cluster that you are configuring:
Name of cluster (for example, osc01r1 or osc01r2)
Zones that are members of this cluster, and the Database Domains where they reside
Host name and IP addresses to be used for SCAN for each cluster
RACs should span across multiple PDomains for high availability. If you are creating a cluster, and a zone in a Database Domain is a member of that cluster on one PDomain, then other zones that are members of that cluster should be in a similar Database Domain on another PDomain.
For example, assume you are creating a two-node cluster, where zone 1 in each Database Domain is a member of that cluster. To ensure high availability, create this cluster with the following zones as members of that cluster:
Zone 1 in Database Domain 1 in PDomain 1
Zone 1 in Database Domain 1 in PDomain 2
The worksheet has entries for ten clusters. But you can have more than ten clusters in your Oracle SuperCluster M6-32, depending on the number of Database Domains that have zones that are members of each cluster, the size of the zones in each cluster, and so on. Copy the worksheet if you have more than ten clusters in your system.
