| Skip Navigation Links | |
| Exit Print View | |
Oracle SuperCluster M6-32 Zones With Oracle Database on Database Domains Configuration Guide |
Planning to Set Up Zones on Database Domains
Extended Configuration PDomain Overview
Understanding Extended Configuration PDomains
Understanding Base Configuration PDomains
Understanding LDom Configurations for Extended Configuration PDomains
Understanding LDom Configurations for Base Configuration PDomains
Determining the Cores Available for LDoms and Zones
Cores Available for Domains and Zones
Zones and Cluster Planning for Database Domains
Guidelines for Planning the Number of Zones and Clusters
Guidelines for Planning the Storage Server Disk Group Layout
Understanding an Example Scenario
Determine the Available Existing Storage Capacity (Example Scenario)
Determine the Amount of Space for Each Disk Group in Each Cluster (Example Scenario)
Recording Your Existing and Planned Configuration Information
Recording Your Zone Configuration Information
Recording Your Cluster Configuration Information
Recording Your Storage Server Disk Group Layout
Preparing to Configure Zones on Database Domains
Determine the Repository Location
Install or Update Packages From the Remote Repository
Install or Update Files From the Local Repository
Verify Configuration Tool Installation
Creating Configuration Files (OEDA)
Verify Storage Server Disk Space for Additional Zones
Locate the Necessary Files to Set Up Zones
Import the Most Recent OEDA Configuration File
Review Existing Configuration Information
Review the Information in the Identify Compute Node Operating System Page
Review the Information in the Management and Private Networks Page
Complete the Define Clusters Page
Set Zone Default Configurations
Complete the Cluster Review and Edit SCAN, Client, VIP, and Optional Backup Networks Page
Verify Remaining Configuration Information
Generate the Configuration Files
Creating the Template Zone on Each Database Domain
Create a Template Zone on a Database Domain
Delete a Template Zone From a Database Domain
Determining if Additional VNETs Are Needed for a Database Domain
Determine if Additional VNETs Are Needed (Using Specific LDom Information)
Determine if Additional VNETs Are Needed (Using Software Commands)
Set Up Public Key Authentication for ZFS Storage Controllers
Creating Additional Links on the IB Storage Network for Zones
Create Additional Links on the IB Storage Network for Zones
In general, follow this process to determine how to lay out your zones and clusters across the storage servers, where each decision point at the top of the process affects decisions made lower in the decision tree.
Determine the amount of existing usable disk space. How many storage servers are available for the clusters that you are creating? How much total usable disk space is available for those clusters?
For more information, see Determine the Available Existing Storage Capacity.
Determine the number of clusters that you want for the zones that you are creating on the Database Domains. This, in conjunction with the total amount of existing usable disk space, is used to determine the maximum amount of space that will be available for each cluster.
For more information, see Determine the Number of Clusters in the System and Maximum Amount of Space Available to Each Cluster.
Determine the amount of space to assign to each of the three disk groups in each cluster.
DATA
RECO
DBFS
Note - There is an option to designate the DBFS disk group set as UNUSED, if necessary.
Also determine the names to use for the disk groups for each cluster. For example, if you are creating disk groups for two clusters (osc01r1 and osc01r2), then you might use these names for the three disk groups for each cluster:
First cluster (osc01r1):
- DATA_osc01r1
- RECO_osc01r1
- DBFS_osc01r1
Second cluster (osc01r2):
- DATA_osc01r2
- RECO_osc01r2
- DBFS_osc01r2
Record your storage server disk group layout in the worksheet in Recording Your Storage Server Disk Group Layout.
For more information, see Determine the Amount of Space for Each Disk Group in Each Cluster.
You must first determine how much existing storage capacity is available before deciding how to carve that storage up for the disk groups for each cluster that you create.
Every storage server contains 12 drives, with the following capacities:
1.2 TB High Performance SAS disk
4 TB High Capacity SAS disk
In addition, the total number of storage servers varies, depending on the type of Exadata Storage Expansion Rack that you have:
Storage rack (part of the Oracle SuperCluster M6-32): 9 storage servers
Optional expansion rack:
Quarter rack: 4 storage servers
Half rack: 9 storage servers
Full rack: 18 storage servers
Finally, the total capacity that you have available depends on the level of redundancy that you want to set for the ASM disk groups (normal redundancy or high redundancy).
The following tables provide capacity information for the Oracle SuperCluster M6-32 storage rack and the expansion rack.
Table 37 Storage Server Storage Capacity in the Oracle SuperCluster M6-32 Storage Rack
Table 38 Storage Server Storage Capacity in the Expansion Rack
The number of clusters in your system varies, depending on several factors, such as:
The logical divisions for the databases in your system, where clusters that are created, and zones that are members of those clusters, might have different functions or audiences.
The number of zones that are available and the number of clusters that can be created with those zones as members, which is partly determined by several factors, such as the number of Database Domains, the size of each Database Domain, and so on.
See Zones and Cluster Planning for Database Domains for more information on how to decide on the total number of zones and clusters in your system.
Once you determine the number of clusters in your system, you can now determine the maximum amount of space that you can assign to each cluster based on the total amount of usable storage that is available. The total amount of space that you assign to all the clusters in the system cannot exceed the total amount of storage that is available.
For example, assume you have a total amount of 48 TB available as usable storage, and you want to create four clusters total in your system, where each cluster has the same overall size. Then the maximum amount of usable space for each cluster would be 12 TB apiece.
Once you have decided on the total amount of disk space to use for each cluster, you must break that total disk space for each cluster down into disk space that is used for the three disk groups within each cluster:
DATA
RECO
DBFS
The DBFS disk group is normally assigned a substantially smaller amount of total disk space than the other two disk groups. You can also designate the DBFS disk group as UNUSED, if necessary.
For example, if 12 TB of space is available for each cluster, you must carve that 12 TB of space up so that the combined disk space used by all three disk groups is 12 TB or less.
