이미지 파일은 zip 형식이며, 이름은 다음과 같습니다.
Oracle_qle83xx_imgx.xx.xxriscy.yy.yy
여기서 x.xx.xx 및 y.yy.yy는 버전 번호입니다.
예: Oracle_qle83xx_img2.02.24risc5.00.41
QConvergeConsole 유틸리티의 Main Menu가 표시됩니다.
QConvergeConsole CLI - Version 1.1.0 (Build 9) Main Menu 1: Adapter Information 2: Adapter Configuration 3: Adapter Updates 4: Adapter Diagnostics 5: Adapter Statistics 6: Refresh 7: Help 8: Exit Please Enter Selection: 3
QConvergeConsole CLI - Version 1.1.0 (Build 9) Fibre Channel Adapter Update 1: Flash Update 2: Paramaters Update 3: Paramaters Template Update 4: Firmware Preload Update 5: FC Serdes Table Update (p or 0: Previous Menu; m or 98: Main Menu; ex or 99: Quit) Please Enter Selection: 1
QConvergeConsole CLI - Version 1.1.0 (Build 9) Flash Update 1: HBA Model: QLE8362 SN: 040200A+1231081525 Port 1 WWPN: 21-00-00-0E-1E-10-51-10 Online Port 2 WWPN: 21-00-00-0E-1E-10-51-11 SFP not installed (p or 0: Previous Menu; m or 98: Main Menu; ex or 99: Quit) Please Enter Selection: 1 Enter a file name or Hit <RETURN> to abort: hld20224.bin
계속하기 전에 QConvergeConsole 유틸리티에 플래시 이미지 파일 이름이 표시됩니다.
QConvergeConsole CLI - Version 1.1.0 (Build 9) Updating the flash image from the current version v020199 to the new version v020224 Do you want to proceed with the operation? 1: Yes 2: No Please Enter Selection: 1
QConvergeConsole CLI - Version 1.1.0 (Build 9) Flash Update: Confirm adapter reset Activate new firmware after upgrade is complete? 1: Yes 2: No Please Enter Selection: 1
Validating Flash Image File... Success Updating Flash on HBA port(s) - QLE8362. Please wait... Updating Adapter FC Boot Code... Success Updating Adapter NIC Boot Code... Success Updating Adapter FCoE Boot Code... Success Updating Adapter CRBInit... Success Updating Adapter BootLoader... Success Updating Adapter PEGTune ... Success Updating Adapter FCoE FW... Success Updating Adapter FC FW... Success Updating Adapter NIC/CNA FW... Success Updating Adapter NIC/CNA VPD... Success Updating Adapter FC VPD... Success Updating Adapter FC VPD... Success Flash update complete. Changes have been saved to the HBA port(s). Hit <Enter> to continue:
펌웨어가 성공적으로 업데이트되었습니다.
