Setup Interface Parameters OXI_HUB
To set the basic functionality parameters for your interface, go to Interface Configuration>Parameters.
OXI_BLOCKS - Block parameters apply if your interface transmits blocks.
OXI_DATAMART - Data message handling.
OXI DATAMART Parameters OXI_HUB
OXI_GENERIC - Generic parameters apply to all interfaces.
OXI_INVENTORY - In case your interface does not transmit full reservations and blocks both ways, inventory may be out of sync in either system and needs to be adjusted with the help of an inventory snapshot
OXI_PROFILES - Profile parameters apply to profiles transmission and determine how the ORS Match & Merge will handle profile management.
OXI_RATES - Rate parameters apply if your interface transmits rates.
OXI_RESERVATIONS - Reservation parameters apply if your interface transmits reservations.
OXI_HUB Reservations Parameters
OXI_STAYS - Stay parameters apply if your interface transmits stay data upload from properties to ORS.
Note: Parameters in OXI_HUB always apply globally, not per property. For example a setting in OXI- V6 will apply to all properties linked to it. Please be cautious when changing parameters from current settings.
