Linux OS Installation Options
You can choose to install an OS on a single server or on multiple servers. The scope
of this document is for single server OS installations. The table below provides some
information about these two installation options.
Multiple servers
Single server
Install an OS to a single server using one of the following
methods:
Locally: Perform the OS installation locally at the
server. This option is recommended if you have just
completed the physical installation of the server in the
rack.
Remotely: Perform the OS installation from a remote
location. Uses the Oracle ILOM Remote System Console Plus
application to access the Oracle System Assistant or to
perform a manual OS installation.
Note -
Oracle recommends the use of Oracle System Assistant for
For more information about single-server OS installation methods and Oracle System
Assistant, see:
Single-Server Installation Methods
Select a method for providing the OS installation media. Use the following
information to determine the local or remote OS installation that best serves your
needs.
Local assisted OS
installation – Uses Oracle System
Assistant. (Recommended)
Remote assisted OS
Oracle ILOM Remote System Console Plus application, an
installation ISO image on a DVD or a network location. For more
information, see Assisted Linux OS
Installation.
Local OS install using a DVD
drive – Uses a physical DVD drive connected
to the server.
A monitor, USB keyboard and mouse, a USB DVD drive, an
installation ISO image on a DVD. For more information, see
Manual Linux OS Installation.
Remote OS install using a DVD drive or
a DVD ISO image – Uses a redirected
physical DVD drive or DVD ISO image on a remote system running
the Oracle ILOM Remote System Console Plus application.
An installation ISO image located on a DVD or a network
location. If using a DVD, an attached physical DVD drive.
Assisted Linux OS Installation
Assisted Linux OS installation is the recommended method for installing a
supported OS on your server. This method involves using Oracle System Assistant. You
deliver the OS installation media on either a local or remote DVD drive, USB device,
or DVD image. The Oracle System Assistant guides the process and gathers and
installs the drivers when necessary. Your server must support Oracle System
Assistant, and it must be installed in the server.
With the manual Linux OS installation method, you deliver the Linux OS
installation ISO image on either a network location or a DVD. You also need to
install any necessary drivers. The drivers for your server are available on the
server's internal Oracle System Assistant flash drive (if installed) and from the My
Oracle Support web site as either OS-specific and server-specific packages or as an
ISO image file. To install the OS, use the installation wizard.
