Supported for SYSTEM_BOARD resources.
saHpiResourcePowerStateSet()
SAHPI_POWER_CYCLE – Implemented with the IPMI chassis control power cycle command.
SAHPI_POWER_ON – Implemented with the IPMI chassis control power up command.
SAHPI_POWER_OFF – Use the IPMI chassis control soft shutdown command first. If the resource does not power off, then use the IPMI chassis control power down command.
