Go to main content
oracle home
Netra Modular System Developer's Guide
Exit Print View
Search Term
Search Scope:
This Document
Entire Library
Documentation Home
Netra Modular System Documentation Library
Programming OEM Controls
LED Controls
LED Set
Updated: August 2015
Document Information
Using This Documentation
Product Documentation Library
Feedback
Understanding the Interfaces and Software
Understanding Interface Options
CLI Overview
SNMP Overview
IPMI Overview
Oracle ILOM Overview
SAF HPI Overview
OpenHPI Overview
Management Software
Programming API Functions
General Functions
Domain Functions
Session Management
Domain Discovery
Resource Presence
Event Logs
Events
Domain Alarms
Resource Functions
Resource Data Record Repository
Sensors
Controls
Inventory Data Repositories
Watchdog Timers
FUMI
Hot-Swap
Reset Management
Power Management
LED Controls
LED Get
LED Set
FRU Configuration Controls
FRU Get
FRU Set
IP Controls
IP Controls Get
IP Controls Set
Point-to-Point Get Controls
Alarm Profile Controls
Alarm Profile Get
Alarm Profile Set
Understanding Netra Modular System Resources
Chassis Resources
TOP_LEVEL_PRODUCT Controls
Modular System Inventory Data Repositories
FMM System Board Resources
FMM System Board Sensors
FMM System Board Inventory Data Repositories
FMM Service Processor Sensors
FMM Service Processor Controls
FMM Service Processor Inventory Data Repositories
Switch Inventory Data Repositories
BMC Inventory Data Repositories
FBN Resources
FBN Sensors
FBN Controls
FBN Inventory Data Repositories
Understanding Oracle Server X5-2M Resources
Node Resources
Node System Resources
System Sensors
System Controls
Motherboard Resources
Motherboard Sensors
Motherboard Inventory Data Repositories
Motherboard Riser Card Sensors
Motherboard/BIOS Inventory Data Repositories
Node SP Resources
SP Controls
SP Inventory Data Repositories
Node Processor Resources
Processor Sensors
Processor Controls
DIMM Resources
DIMM Sensors
DIMM Controls
DIMM Inventory Data Repositories
Disk Drive Resources
Disk Drive Sensors
Disk Drive Controls
Disk Drive Backplane Inventory Data Repositories
Node Power Supply Resources
Power Supply Sensors
Power Supply Inventory Data Repositories
Node PCIe Slot Resources
Node Fan Module Resources
Fan Module Sensors
Fan Module Controls
Node BMC Resources
Understanding Switch Resources
Switch Resources
Switch System Resources
Switch System Sensors
Switch System Controls
Switch System Inventory Data Repositories
Switch Power Supply Resources
Switch Fan Module Resources
Fan Module Sensors
Fan Module Controls
Switch SP Resources
SP Sensors
SP Controls
Switch BMC Inventory Data Repositories Resources
Switch Chassis Resources
Chassis Sensors
Chassis Inventory Data Repositories
Glossary
Index
Index A
Index B
Index C
Index D
Index E
Index F
Index G
Index H
Index I
Index L
Index M
Index N
Index O
Index P
Index R
Index S
Index T
Index W
Language:
English
LED Set
Parameter
Input
SessionId
Session ID
ResourceId
Resource ID
CtrlNum
LED control number
CtrlMode
SAHP_CTRL_MODE_MANUAL
CtrlState.Type
SAHPI_CTRL_TYPE_OEM
CtrlState.StateUnion.Oem.Body[0]
0
if the LED is off
1
if the LED is on
Related Information
LED Get
Previous
Next
