The operating version of an IGS switch on a VLAN can be V1, V2, or V3. This section describes the configuration of IGMP version on a VLAN. If you have questions about the topology used in this section, see Flow-Based Configuration Example. For the default settings, see Default Settings.
SEFOS# configure terminal SEFOS(config)# snooping multicast-forwarding-mode mac
SEFOS(config)# set gmrp disable
SEFOS(config)# ip igmp snooping
SEFOS(config)# vlan 2
SEFOS(config-vlan)# ports extreme-ethernet 0/1-2
SEFOS(config-vlan)# ip igmp snooping version v2 SEFOS(config-vlan)# exit
SEFOS(config)# vlan 3
SEFOS(config-vlan)# ports extreme-ethernet 0/3-4
SEFOS(config-vlan)# ip igmp snooping version v3 SEFOS(config-vlan)# exit
SEFOS(config)# interface extreme-ethernet 0/1
SEFOS(config-if)# switchport pvid 2
SEFOS(config-if)# no shutdown SEFOS(config-if)# exit
SEFOS(config)# interface extreme-ethernet 0/2
SEFOS(config)# interface extreme-ethernet 0/3
SEFOS(config-if)# switchport pvid 3
SEFOS(config)# interface extreme-ethernet 0/4
SEFOS(config-if)# no shutdown SEFOS(config-if)# end
SEFOS# show ip igmp snooping globals Snooping Configuration ----------------------------- IGMP Snooping globally enabled IGMP Snooping is operationally enabled IGMP Snooping Enhanced mode is disabled Transmit Query on Topology Change globally disabled Multicast forwarding mode is MAC based Proxy globally disabled Proxy reporting globally enabled Filter is disabled Router port purge interval is 125 seconds Port purge interval is 260 seconds Report forward interval is 5 seconds Group specific query interval is 2 seconds Reports are forwarded on router ports Group specific query retry count is 2 Multicast VLAN disabled Leave config level is Vlan based
SEFOS# show ip igmp snooping vlan 2
Snooping VLAN Configuration for the VLAN 2
IGMP Snooping enabled
IGMP configured version is V2
Fast leave is disabled
Snooping switch is configured as Non-Querier
Snooping switch is acting as Non-Querier
Query interval is 125 seconds
Port Purge Interval is 260 seconds
Max Response Code is 100, Time is 10 seconds
SEFOS# show ip igmp snooping vlan 3
Snooping VLAN Configuration for the VLAN 3
IGMP configured version is V3
SEFOS# show vlan id 2 Vlan database-------------------Vlan ID : 2Member Ports : Ex0/1, Ex0/2Untagged Ports : NoneForbidden Ports : NoneName :Status : Permanent----------------------------------------------------
SEFOS# show vlan id 3 Vlan database------------------Vlan ID : 3Member Ports : Ex0/3, Ex0/4Untagged Ports : NoneForbidden Ports : NoneName :Status : Permanent----------------------------------------------------
SEFOS# show ip igmp snooping vlan 2 Snooping VLAN Configuration for the VLAN 2 IGMP Snooping enabled IGMP configured version is V2 Fast leave is disabled Snooping switch is configured as Non-Querier Snooping switch is acting as Non-Querier Query interval is 125 seconds Port Purge Interval is 260 seconds Max Response Code is 100, Time is 10 seconds
SEFOS# show ip igmp snooping vlan 3 Snooping VLAN Configuration for the VLAN 3 IGMP Snooping enabled IGMP configured version is V3 Fast leave is disabled Snooping switch is configured as Non-Querier Snooping switch is acting as Non-Querier Query interval is 125 seconds Port Purge Interval is 260 seconds Max Response Code is 100, Time is 10 seconds
