When IGS is enabled globally, it is enabled in all of the existing VLAN interfaces. When IGMP snooping is disabled globally, it is disabled in all of the existing VLAN interfaces.
SEFOS# configure terminal SEFOS(config)# vlan 2
SEFOS(config-vlan)# ip igmp snooping SEFOS(config-vlan)# end
SEFOS# show ip igmp snooping vlan 2 Snooping VLAN Configuration for the VLAN 2 IGMP Snooping enabled IGMP configured version is V3 Fast leave is disabled Snooping switch is configured as Non-Querier Snooping switch is acting as Non-Querier Query interval is 125 seconds Port Purge Interval is 260 seconds Max Response Code is 100, Time is 10 seconds
When IGS is enabled and disabled globally, but not enabled on VLAN 2, the show command produces:
Snooping VLAN Configuration for the VLAN 2 IGMP Snooping is disabled IGMP configured version is V3 Fast leave is disabled Snooping switch is configured as Non-Querier Snooping switch is acting as Non-Querier Query interval is 125 seconds Port Purge Interval is 260 seconds Max Response Code is 100, Time is 10 seconds
