- Enter
Global Configuration mode.
SEFOS# configure terminal
- Enable report forwarding on all
ports.
SEFOS(config)# ip igmp snooping report-forward all-ports
SEFOS(config)# end
- Review the configuration.
SEFOS# show ip igmp snooping globals
Snooping Configuration
IGMP Snooping globally enabled
IGMP Snooping is operationally enabled
IGMP Snooping Enhanced mode is disabled
Transmit Query on Topology Change globally disabled
Multicast forwarding mode is MAC based
Proxy globally disabled
Proxy reporting globally enabled
Filter is disabled
Router port purge interval is 125 seconds
Port purge interval is 260 seconds
Report forward interval is 5 seconds
Group specific query interval is 2 seconds
Reports are forwarded on all ports
Group specific query retry count is 2
Multicast VLAN disabled
Leave config level is Vlan based
