SEFOS# configure terminal
SEFOS# show ip igmp snooping forwarding-database
Vlan MAC-Address Ports
1 01:00:5e:01:01:01 Ex0/1
SEFOS(config)# ip igmp snooping port-purge-interval 130 SEFOS(config)# end
If an entry is learned on the forwarding database, then after an interval of 130 seconds, the entry is removed from the forwarding database.
SEFOS# show ip igmp snooping globals Snooping Configuration ----------------------------- IGMP Snooping globally enabled IGMP Snooping is operationally enabled IGMP Snooping Enhanced mode is disabled Transmit Query on Topology Change globally disabled Multicast forwarding mode is MAC based Proxy globally disabled Proxy reporting globally enabled Filter is disabled Router port purge interval is 125 seconds Port purge interval is 130 seconds Report forward interval is 5 seconds Group specific query interval is 2 seconds Reports are forwarded on router ports Group specific query retry count is 2 Multicast VLAN disabled Leave config level is Vlan based
