Oracle VM Server Installation Options
You can choose to install Oracle VM Server on a single server or on multiple
servers. The scope of this document is for single server Oracle VM Server
installations. The table below provides some information about these two installation
options.
Install Oracle VM Server to a single server using one of the
following methods:
Locally: Perform the Oracle VM Server installation
with physical access to the server. This option is
recommended if you have just completed the physical
installation of the server in the rack.
Remotely: Perform the Oracle VM Server installation
from a remote location. This option uses the Oracle ILOM
Remote System Console Plus application to perform a manual
Oracle VM Server installation.
Single-Server Installation Methods
Select a method for providing the Oracle VM Server installation media. Use the
following information to determine the local or remote Oracle VM Server
installation that best meets your needs.
Local Oracle VM Server
installation using a DVD drive – Uses a
physical DVD drive connected to the server.
Remote Oracle VM Server
installation using a DVD drive or DVD ISO image
– Uses a redirected physical DVD drive on a remote system
running the Oracle ILOM Remote System Console Plus
application.
A remote system with a web browser, an attached physical DVD
drive, the Oracle VM Server installer ISO image on a DVD,
and network access to the server management port (NET MGT). For
more information, see Manual Oracle VM Server Installation.
PXE Image –
Uses the server Preboot eXecution Environment (PXE) to launch
the Oracle VM installer from a network interface.
To install Oracle VM Server manually, you deliver the Oracle VM Server
distribution media on either a local or remote DVD drive, USB device, or DVD image.
You also need to install any necessary drivers. The drivers for your server are
included with the Oracle VM Server distribution media, and from the My Oracle
Support web site as either OS-specific or server-specific packages, or as an ISO
image file. To install Oracle VM Server, use the distribution media's
installation wizard.
To access the My Oracle Support web site, go to https://support.oracle.com.
