Ensure that the following requirements are met:
You have access to the host console. For more information, see Selecting the Console Display.
You have prepared the boot environment. For more information, see Preparing the Boot Environment.
You have prepared the boot media. For more information, see Selecting the Boot Media Option.
You have selected the installation target and ensured that it is properly installed. For more information, see Selecting the Installation Target.
Two systems with static IP addresses have been set up:
One system to install Oracle VM Server.
One system for Oracle VM Manager with one of the following:
Oracle Linux 5 Update 5, 64-bit or later
Oracle Linux 6, 64-bit or later
Oracle Linux 7, 64-bit or later
Red Hat Enterprise Linux 5 Update 5, 64-bit or later
Red Hat Enterprise Linux 6, 64-bit or later
Red Hat Enterprise Linux 7, 64-bit or later
You have reviewed the additional preinstallation tasks and requirements in the Oracle VM Installation and Upgrade Guide for Release 3.4 at http://www.oracle.com/technetwork/documentation/vm-096300.html.
You have access to the Oracle VM installation documentation. The Oracle VM Release 3.4 Documentation Library is available at http://www.oracle.com/technetwork/documentation/vm-096300.html.
