1.
Review the server product notes.
2.
Install the server hardware.
3.
Configure the service processor.
4.
Review the Oracle VM Server versions supported on the server.
5.
Set up a second system with a static IP address on which
you can install the Oracle VM Manager. This system must have one of
the following operating systems installed:
Oracle Linux 5 Update 5, 64-bit or later
Oracle Linux 6, 64-bit or later
Oracle Linux 7, 64-bit or later
Red Hat Enterprise Linux 5 Update 5, 64-bit or later
Red Hat Enterprise Linux 6, 64-bit or later
Red Hat Enterprise Linux 7, 64-bit or later
6.
Obtain the Oracle VM Server installation media and the
Oracle VM documentation. The Oracle VM documentation
should be used in conjunction with the installation procedures in
this guide.
7.
Set up the boot environment, console, boot media, and installation target that you will use to perform the installation.
8.
Install Oracle VM Server and, if necessary, Oracle VM
Manager.
9.
Perform the post installation tasks, if applicable.
