Business Processes and Rules: Siebel Enterprise Application Integration > Data Mapping Using Scripts > MIME Message Objects and Methods > CSSEAIMimeMsgOutThis object represents an output MIME message, open for writing. This object provides SetArgument, CreateXMLPart, SetAttachmentSource, and CopyAttachment methods: SetArgument() MethodThis method sets the value of a business service argument. Table 39 presents the parameters for this method. Syntax
ReturnsUsageYou can call the SetArgument method to establish the value of a given output argument for the business service method invocation. CreateXMLPart() MethodThis method is similar to XPSCreateRootElement. See XPSCreateRootElement(). CreateXMLPart() Method creates an XML MIME part and adds it to the MIME document. The property set representing the XML root element is returned. The property set returned can be populated using the XML Property Set functions. See XML Property Set Functions. Table 40 presents the parameter for this method. Syntax
ReturnsSetAttachmentSource() MethodThis method establishes the source object from which to copy attachment objects. The source object must be a CSSEAIIntMsgIn, CSSEAIMimeMsgIn, or other object implementing the GetAttachmentByCID method. Table 41 presents the parameter for this method. SyntaxCopyAttachment() MethodThis method copies an attachment from the attachment source to the output MIME message object. The attachment is referenced by the MIME Content Identifier (CID). The attachment copy, a property set, is returned. The attachment source must be established by calling CSSEAIMimeMsgOut.SetAttachmentSource before calling this method. Table 42 presents the parameter for this method. SyntaxReturnsProperty set. This method returns null if the attachment source does not contain an attachment with the specified CID. |
| Business Processes and Rules: Siebel Enterprise Application Integration | Copyright © 2015, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
