Siebel Order Management Infrastructure Guide > Data Transfer Utilities Business Service > About Data Maps >
Data Map Components
Data map components define the mapping at the child business component level. Each data map object can contain multiple data map components. You can arrange data map components in a parent-child hierarchy, but you must specify a parent for all except one data map component. The parentless data map component is called the root data map component. Data map components are described in Table 45.
Table 45. Data Map Components
Name |
Data map component name. Enter a unique name for each data map component in a data map object. |
Source or Destination Business Component |
Source or destination business component name. If you specify a parent for this data map component, you must define this business component in the Siebel repository file as a child of the source or destination business object to which the parent data map component is mapped. |
Parent |
Parent data map component name. If you:
- Specify a parent, the parent is mapped to particular source and destination business components. Generally, you map the child data map component to a child of those source and destination business components.
- Do not want to specify a parent, leave it empty to indicate that this is the root data map component. Each data map object can have one or more root data map components.
Inactive |
Check this box to make the data map component inactive. |
