또한 수신 패킷이 VLAN의 멤버 포트에서 올바르게 전환되는지 여부를 테스트합니다.
Connect to SEFOS을 참조하십시오.
SEFOS-1# show vlan Vlan database ------------- Vlan ID : 101 Member Ports : X10/1,X10/2,X10/21,X10/22 Untagged Ports : X10/1,X10/2,X10/21,X10/22 Forbidden Ports : None Reflective-Relay : Disabled Name : Status : Other
# ping -s 20.0.0.20
# ping 20.0.0.10
SEFOS-2# configure terminal SEFOS-2(config)# vlan 101 SEFOS-1(config-vlan)# ports xl-ethernet 0/25,0/1-2 untagged xl-ethernet 0/25,0/1-2
SEFOS-2# config terminal SEFOS-2(config)# interface xl-ethernet 0/25 SEFOS-2(config-if)# no shutdown SEFOS-2(config-if)# end
SEFOS-2# show vlan Vlan database ------------- Vlan ID : 101 Member Ports : X10/1,X10/21, X10/22 Untagged Ports : X10/1,X10/21, X10/22 Forbidden Ports : None Reflective-Relay : Disabled Name : Status : Other
ping이 성공적으로 수행되어야 합니다.
# ping -s 20.0.0.20 # ping -s 20.0.0.30
