Salir de la Vista de impresión
Use estas tareas para configurar el entorno del SEFOS para el conmutador.
Enable or Disable the Timeout for Line Connections
Configure the IP Address for an Interface
Configure the Name of the Configuration File
Configure the Default VLAN ID
Enable or Disable Trap Generation on an Interface
Configure Debug Logging
Configure ACL Filters
Configure QoS
Configure Port Mirroring
Configure Rate Limiting
Configuring Save Parameters
SEFOS Setup Tasks
Understanding SEFOS Basics
Managing Configuration Files
Managing Log Files
