The iocard command adds, resets, removes, and displays available I/O line card information in the system. The virtualization switch supports up to 12 I/O cards, while the leaf switch supports only one I/O card. You can configure vHBAs on a virtualization switch, but not on a leaf switch.
add iocard {slot|wildcard} card-type [–noconfirm]
remove iocard {*|slot}
remove iocard {*|slot} vhbas [–noconfirm]
remove iocard {*|slot} vnics [–noconfirm]
set iocard {*|slot} clear-stats [–descr=text] [–fabric-mtu=mtu] [–type=card-type]
set iocard {*|slot} reset [–descr=text] [–fabric-mtu=mtu] [–type=card-type]
show iocard
show iocard *
show iocard {slot|wildcard}
show iocard {slot|wildcard} alarms
show iocard {slot|wildcard} cpu [–detail]
show iocard {slot|wildcard} dmesg [–detail]
show iocard {slot|wildcard} errors
show iocard {slot|wildcard} ioport {*|port} [–detail]
show iocard {slot|wildcard} ioports [–detail]
show iocard {slot|wildcard} stats [–detail]
show iocard {slot|wildcard} vnics [–detail[
show iocard {slot|wildcard} warnings
where:
card-type is the type of I/O card you are adding or configuring. For example, gwEthernet4Port10GbCard.
slot is the physical slot number.
port is the physical port number.
This hardware command has subcommands that determine its functionality. This table describes the subcommands and provides their syntax.
These commands are supported on I/O cards only. The front panel, SCP, and IB fabric board are not affected.
This example shows how to reset I/O card 2 and view the results.
[OFOS] set iocard 2 reset Resetting IO cards will adversely affect any virtual IO resource connected to them and thus cut I/O to the physical servers. Are you sure you want to reset the IO card in slot 2 (y/n)? y [OFOS] show iocard slot state descr type v-resources ------------------------------------------------------------------------- 1 up/down gwEthernet4Port10GbCard 0 2 up/up gwEthernet4Port10GbCard 0 3 up/up gwEthernet4Port40GbCard 0 4 up/up gwEthernet4Port10GbCard 0 embedded up/up spineIb4Gw2PortCard 0 5 records displayed
This example shows how to display all I/O cards and remove the card in slot 3.
[OFOS] show iocard ? Possible completions: 2 sanFc2Port16GbCard in slot 2 3 gwEthernet4Port10GbCard in slot 3 4 gwEthernet4Port40GbCard in slot 4 embedded nsmCard in slot 5 7 sanFc2Port16GbCard in slot 7 8 ibLr4Port100GbCard in slot 8 9 ibSfm4Port100GbCard in slot 9 10 ibSlm8Port100GbCard in slot 10 [OFOS] remove iocard 3 This may disrupt traffic on all physical server that happen to be using the IO card. Remove iocard in slot 3 (y/n)? y
This example shows how to remove all vHBAs connected to the I/O card in slot 2.
[OFOS] remove iocard 2 vhbas Remove all vhbas from iocard in slot 2 (y/n)? y
This example shows how to view information for I/O card 2.
[OFOS] show iocard 2 -------------------------------- slot 2 state up/up descr type gwEthernet4Port40GbCard vnics 0 qos default acl xmsGeneratedAclSet enables --s-- -------------------------------- 1 record displayed
The field v-resources indicates the number of Oracle Fabric OS virtual resources (vNICs and vHBAs) that are associated with this card. vNICs can be bound only to network Ethernet cards.
This example displays port information for I/O card 3.
[OFOS] show iocard 3 ioport name type state descr mode lag access-vlan guid --------------------------------------------------------------------------------------------- 3/1 gwEthernet10GbPort up/up trunk 1 10e08b50870102 3/2 gwEthernet10GbPort up/up trunk 1 10e08b50870102 3/3 gwEthernet10GbPort up/up trunk 1 10e08b50870102 3/4 gwEthernet10GbPort up/up trunk 1 10e08b50870102 4 records displayed
The field v-resources indicates the number of Oracle Fabric OS virtual resources (vNICs and vHBAs,) that are associated with this card. vNICs can be bound only to network Ethernet cards.
