These topics describe how to use the CLI commands in Oracle Fabric OS to manage the Oracle InfiniBand Switch IS2-46 (the leaf switch), the Oracle EDR InfiniBand Fabric, and the Oracle Fabric Interconnect F2-12 switch (the virtualization switch) For detailed information about concepts and procedures, refer to the Oracle Fabric OS 1.0.2 Administration Guide.
The Oracle Fabric OS includes commands to configure the following elements:
Virtual Resources – These resources, such as vNICs and vHBAs, provide virtual I/O for your systems. VHBAs and modules are supported only on the virtualization switch.
File System – A file storage system.
Hardware – Servers, I/O cards, and system logs.
Scripting Engine – Ability to run scripts within the Oracle Fabric OS for each I/O card. The engine also enables you to define new commands. Script support in the Oracle Fabric OS includes a full text editor for writing and revising your scripts. Refer to Creating Scripts in Oracle Fabric OS 1.0.2 Administration Guide.
