Identify the prerequisite and subsequent installation tasks that you must
perform in conjunction with this task.
See Installation Task Overview.
Attach the cable to the appropriate connector of the node or host.
Route and bundle the data cables through the physical topology.
Bring the cable to the location in the rack where the module is
installed.
If a plug is present, remove the plug from the optical transceiver receptacle.
Orient the optical transceiver squarely and horizontally with the QSFP+ port
that you selected, then carefully insert the transceiver into the port on the
module until you feel a detent or click.
Note -
Ensure the metal clip on the optical transceiver is in the closed
position.
Remove the protective cap from the fiber cable connector. Orient the cable
connector into the transceiver's receptacle squarely and horizontally, until you
Repeat Step 2 to
Step 6 for any
other transceivers and cables to be connected.
If the rack rear door is installed, close and secure it.
Verify the module installation.
See Verify Module Installation.
