Go to main content
手册页部分 1:用户命令
退出打印视图
更新时间: 2018年8月8日 星期三
gnome-help (1)
名称
gnome-help - GNOME help browser
用法概要
yelp  [--private-session] [--with-cache-dir=string] [gnome-std-options]
url
描述
yelp(1)                          User Commands                         yelp(1)
NAME
       yelp, gnome-help - GNOME help browser
SYNOPSIS
       url
DESCRIPTION
       The GNOME help browser is a utility that allows users to view  documen-
       tation for GNOME in several formats including man pages, Mallard, HTML,
       SGML(DocBook), and GNU info files.
OPTIONS
       The following options are supported:
       --private-session               Use a private session.
       --with-cache-dir=directory      Specify which cache directory to use.
       gnome-std-options               Standard options available for use with
                                       most  GNOME  applications.   See gnome-
                                       std-options(7) for more information.
OPERANDS
       The following operands are supported:
       url             This allows you to view a  specific  help  document  by
                       providing  the  complete  url to the documentation that
                       you wish to view.
                       If url starts with "ghelp:", yelp opens the help  docu-
                       ment within ghelp.
                       If  url  does not start with "ghelp:", yelp attempts to
                       launch a default Internet browser  window  and  display
                       the  contents  of the help document within this browser
                       window.
EXTENDED DESCRIPTION
       Refer to the GNOME Documentation Project webpages:
       https://wiki.gnome.org/DocumentationProject/
EXAMPLES
       Example 1: Launching GNOME Help Browser
       example% yelp
       Example 2: Launching GNOME Help Browser and loading the  help  informa-
       tion for the GNOME Accessibility guide.
       example% yelp ghelp:///usr/share/gnome/help/gnome-access-guide/C/gnome-access-guide.xml
       Example 3: Launching GNOME Help Browser with a standard Internet URL
       example% yelp http://www.gnome.org
       The  default  Internet browser is launched (unless a browser is already
       running), and this URL is displayed within the browser window.
ENVIRONMENT VARIABLES
       See environ(7) for descriptions of the following environment variables:
       INFOPATH                Location of GNU Info files.
       MANPATH                 Location of man pages.
EXIT STATUS
       The following exit values are returned:
       0        Application exited successfully
       >0       Application exited with failure
ATTRIBUTES
       See attributes(7) for descriptions of the following attributes:
       |ATTRIBUTE TYPE |    ATTRIBUTE VALUE     |
       |Availability   | gnome/help-viewer/yelp |
       |Stability      | Pass-through volatile  |
SEE ALSO
       Latest version of the GNOME Desktop User Guide for your platform.
       attributes(7), environ(7), gnome-std-options(7)
NOTES
       yelp and gnome-help are the same application.
       Written by Matt Keenan, Sun Microsystems Inc., 2003, 2007.
       This    software    was    built    from    source     available     at
       https://github.com/oracle/solaris-userland.    The  original  community
       source        was        downloaded         from          https://down-
       load.gnome.org/sources/yelp/3.22/yelp-3.22.0.tar.xz
       Further information about this software can be found on the open source
       community website at https://wiki.gnome.org/Apps/Yelp.
Solaris 11.4                      7 Apr 2017                           yelp(1)
