Go to main content
手册页部分 1:用户命令
退出打印视图
更新时间: 2018年8月8日 星期三
gnome-system-monitor (1)
名称
gnome-system-monitor - view system processes and monitor system usage
用法概要
gnome-system-monitor [gnome-std-options]
描述
gnome-system-monitor(1)          User Commands         gnome-system-monitor(1)
NAME
SYNOPSIS
DESCRIPTION
       The System Monitor application displays a list of system processes, and
       monitors system usage. System Monitor shows which processes are running
       and how the processes are related.
       System Monitor also provides detailed information about individual pro-
       cesses, and enables the user to control which  processes  are  running.
       System Monitor displays how much processor (CPU) capacity the system is
       using, and how much disk space the system is using on each device.
       System Monitor displays this information in a  graphical  interface  so
       that  users  can  see  what the system is doing. Users can then use the
       same graphical interface to modify the behavior of the system.
OPTIONS
       The following options are supported:
       gnome-std-options       Standard options available for  use  with  most
                               GNOME  applications.   See gnome-std-options(7)
                               for more information.
ENVIRONMENT VARIABLES
       See environ(7) for descriptions of the following environment  variables
       that affect the execution of gnome-system-monitor: NLSPATH.
EXIT STATUS
       The following exit values are returned:
       0        Application exited successfully
       >0       Application exited with failure
ATTRIBUTES
       See attributes(7) for descriptions of the following attributes:
       |ATTRIBUTE TYPE |              ATTRIBUTE VALUE                |
       |Availability   | desktop/system-monitor/gnome-system-monitor |
       |Stability      | Pass-through volatile                       |
SEE ALSO
       System Monitor Manual
       Latest version of the GNOME Desktop User Guide for your platform.
       top(1), prstat(8), attributes(7), environ(7), gnome-std-options(7)
NOTES
       Written  by Niall Power, Sun Microsystems Inc., 2003.  Updated by Henry
       Zhang, Sun Microsystems Inc., 2006.
       This    software    was    built    from    source     available     at
       https://github.com/oracle/solaris-userland.    The  original  community
       source was downloaded  from   https://download.gnome.org/sources/gnome-
       system-monitor/3.24/gnome-system-monitor-3.24.0.tar.xz
       Further information about this software can be found on the open source
       community  website  at  https://help.gnome.org/users/gnome-system-moni-
       tor/.
Solaris 11.4                      7 Apr 2017           gnome-system-monitor(1)
