Go to main content
手册页部分 1:用户命令
退出打印视图
更新时间: 2018年8月8日 星期三
swift-container-info (1)
名称
swift-container-info - info tool
用法概要
swift-container-info [CONTAINER_DB_FILE] [SWIFT_DIR]
描述
swift-container-info(1)         OpenStack Swift        swift-container-info(1)
NAME
       swift-container-info - Openstack Swift container-info tool
SYNOPSIS
DESCRIPTION
       This  is  a  very  simple  swift tool that allows a swiftop engineer to
       retrieve information about a container that is located on  the  storage
       node.   One  calls  the  tool  with  a given container db file as it is
       stored on the storage node system.  It will then return several  infor-
       mation about that container such as;
       - Account it belongs to
       - Container
       - Created timestamp
       - Put timestamp
       - Delete timestamp
       - Object count
       - Bytes used
       - Reported put timestamp
       - Reported delete timestamp
       - Reported object count
       - Reported bytes used
       - Hash
       - ID
       - User metadata
       - X-Container-Sync-Point 1
       - X-Container-Sync-Point 2
       - Location on the ring
DOCUMENTATION
       More   documentation   about   Openstack   Swift   can   be   found  at
       http://swift.openstack.org/index.html
ATTRIBUTES
       See attributes(7) for descriptions of the following attributes:
       |ATTRIBUTE TYPE |   ATTRIBUTE VALUE     |
       |Availability   | cloud/openstack/swift |
       |Stability      | Uncommitted           |
SEE ALSO
       swift-get-nodes(1), swift-object-info(1)
NOTES
       This    software    was    built    from    source     available     at
       https://github.com/oracle/solaris-userland.    The  original  community
       source      was      downloaded      from        https://tarballs.open-
       stack.org/swift/swift-2.7.0.tar.gz
       Further information about this software can be found on the open source
       community website at http://www.openstack.org/.
OpenStack                          3/20/2013           swift-container-info(1)
