Go to main content
手册页部分 1:用户命令
退出打印视图
更新时间: 2018年8月8日 星期三
help2man (1)
名称
help2man - generate a simple manual page
用法概要
help2man [OPTION]... EXECUTABLE
描述
HELP2MAN(1)                      User Commands                     HELP2MAN(1)
NAME
SYNOPSIS
DESCRIPTION
       `help2man' generates a man page out of `--help' and `--version' output.
       -n, --name=STRING
              description for the NAME paragraph
       -s, --section=SECTION
              section number for manual page (1, 6, 8)
       -m, --manual=TEXT
              name of manual (User Commands, ...)
       -S, --source=TEXT
              source of program (FSF, Debian, ...)
       -L, --locale=STRING
              select locale (default "C")
       -i, --include=FILE
              include material from `FILE'
       -I, --opt-include=FILE
              include material from `FILE' if it exists
       -o, --output=FILE
              send output to `FILE'
       -p, --info-page=TEXT
              name of Texinfo manual
       -N, --no-info
              suppress pointer to Texinfo manual
       -l, --libtool
              exclude the `lt-' from the program name
       --help print this help, then exit
       --version
              print version number, then exit
       EXECUTABLE  should  accept `--help' and `--version' options and produce
       output on stdout although alternatives may be specified using:
       -h, --help-option=STRING
              help option string
       -v, --version-option=STRING
              version option string
       --version-string=STRING
              version string
       --no-discard-stderr
              include stderr when parsing option output
INCLUDE FILES
       Additional material may be included in the generated  output  with  the
       --include and --opt-include options.  The format is simple:
           [section]
           text
           /pattern/
           text
       Blocks  of  verbatim  *roff text are inserted into the output either at
       the start of the given [section] (case insensitive), or after  a  para-
       graph matching /pattern/.
       Patterns  use the Perl regular expression syntax and may be followed by
       the i, s or m modifiers (see perlre(1)).
       Lines before the first section or pattern which begin with `-' are pro-
       cessed  as  options.  Anything else is silently ignored and may be used
       for comments, RCS keywords and the like.
       The section output order (for those included) is:
           NAME
           SYNOPSIS
           DESCRIPTION
           OPTIONS
           ENVIRONMENT
           FILES
           EXAMPLES
           other
           AUTHOR
           REPORTING BUGS
           COPYRIGHT
           SEE ALSO
       Any [NAME] or [SYNOPSIS] sections appearing in the  include  file  will
       replace  what  would have automatically been produced (although you can
       still override the former with --name if required).
       Other sections are prepended to the automatically produced  output  for
       the  standard sections given above, or included at other (above) in the
       order they were encountered in the include file.
       Placement of the text within the section may be explicitly requested by
       using  the  syntax  [<section],  [=section]  or [>section] to place the
       additional text before, in  place  of,  or  after  the  default  output
       respectively.
AVAILABILITY
       The latest version of this distribution is available on-line from:
           ftp://ftp.gnu.org/gnu/help2man/
AUTHOR
       Written by Brendan O'Dea <bod@debian.org>
REPORTING BUGS
       Report bugs to <bug-help2man@gnu.org>.
COPYRIGHT
       Copyright  (C)  1997,  1998,  1999, 2000, 2001, 2002, 2003, 2004, 2005,
       2009, 2010, 2011, 2012, 2013, 2014, 2015 Free Software Foundation, Inc.
       This is free software; see the source for copying conditions.  There is
       NO  warranty;  not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR
       PURPOSE.
ATTRIBUTES
       See attributes(7) for descriptions of the following attributes:
       |ATTRIBUTE TYPE |           ATTRIBUTE VALUE             |
       |Availability   | developer/documentation-tool/help2man |
       |Stability      | Uncommitted                           |
SEE ALSO
       The full documentation for help2man is maintained as a Texinfo  manual.
       If  the info and help2man programs are properly installed at your site,
       the command
              info help2man
       should give you access to the complete manual.
NOTES
       This    software    was    built    from    source     available     at
       https://github.com/oracle/solaris-userland.    The  original  community
       source       was       downloaded       from        http://mirror.team-
       cymru.org/gnu/help2man/help2man-1.47.4.tar.xz
       Further information about this software can be found on the open source
       community website at https://www.gnu.org/software/help2man.
help2man 1.47.4                    May 2016                        HELP2MAN(1)
