Go to main content
Oracle® Quad Port 10GBase-T Adapter User's Guide
Exit Print View
Updated: June 2019
Analyze Why the Link Is Not Up After Back-To-Back Cable Connection (Oracle Solaris)
  1. Ensure that you are using the correct cable type.
    See Supported Cables.
  2. Check the auto-neg/link settings on both peers to ensure that they are compatible.
Related Information
