ok show-nets a) /niu@480/network@0 b) /pci@400/pci@2/pci@0/pci@c/network@0,3 c) /pci@400/pci@2/pci@0/pci@c/network@0,2 d) /pci@400/pci@2/pci@0/pci@c/network@0,1 e) /pci@400/pci@2/pci@0/pci@c/network@0 f) /pci@400/pci@2/pci@0/pci@a/network@0,1 g) /pci@400/pci@2/pci@0/pci@a/network@0 q) NO SELECTION Enter Selection, q to quit: q
These examples assume that /pci@400/pci@2/pci@0/pci@c/network@0 is a port on the adapter.
ok cd /pci@400/pci@2/pci@0/pci@c/network@0
ok .properties
The output should be similar to this:
vf-assigned-addresses c3050000 00000041 01010000 00000000 00010000
c3050003 00000041 01210000 00000000 00004000
assigned-addresses c3050010 00000041 00000000 00000000 01000000
c305001c 00000041 01000000 00000000 00008000
82050030 00000000 00200000 00000000 00080000
vf-reg 43050000 00000000 00000000 00000000 00010000
43050003 00000000 00000000 00000000 00004000
reg 00050000 00000000 00000000 00000000 00000000
43050010 00000000 00000000 00000000 01000000
4305001c 00000000 00000000 00000000 00008000
02050030 00000000 00000000 00000000 00080000
local-mac-address 3c fd fe 50 00 f0
version Oracle Quad Port 10GBase-T Adapter FCode 3.7 10/18/2016
board-model 7096675
model 7111181/7111182
compatible pciex8086,1589.108e.7b1c.1
pciex8086,1589.1
pciex8086,1589
pciexclass,020000
pciexclass,0200
address-bits 00000030
max-frame-size 00002400
network-interface-type ethernet
device_type network
name network
fcode-rom-offset 00059c00
vf-stride 00000001
first-vf-offset 00000010
total-vfs 00000020
initial-vfs 00000020
#vfs 00000020
port-type PCIE-Endpoint
interrupts 00000001
cache-line-size 00000010
class-code 00020000
subsystem-id 00007b1c
subsystem-vendor-id 0000108e
revision-id 00000002
device-id 00001589
vendor-id 00008086
{0} ok
If you do not see the device listed, check that the adapter is properly seated. If necessary, reinstall the adapter.
ok device-end
