Usage Information
Oracle 6.4 TB NVMe SSD v2s operate and are stored in an environment defined by the parameters
and specifications in the following table.
Operating temperature
0 to 35°C ambient, 0 to 70°C case with specified
airflow
Operational environment: 5°C to 35°C (dry bulb)
Non-operating temperature
Storage and transit environment: –55°C to 95°C (dry
bulb)
Temperature monitoring
Temperature monitoring in-band and by way of SMBUS
Thermal sensors
Thermal sensors on the storage drives monitor flash memory
modules
Dry bulb temperature
Maximum dry bulb temperature is derated by 3.3°C per 1000 m
above 500 m
Altitude (Simulated)
Operating: -1,000 to 10,000 ft
Non-operating: -1,000 to 40,000 ft
Relative humidity range
Operational environment: 8% to 80%
noncondensing
Storage and transit environment: 5% to 95%
noncondensing
Non-operating: -20°C to 75°C noncondensing
Airflow requirement
More than 450 LFM (linear feet/minute) at 25/35°C, airflow
towards the connector
Temperature Sensor
Internal temperature sensor with an accuracy of +/-2°C over a
range of -10°C to +85°C.
Internal temperature sensor can be monitored using NVMe Health
Log.
The sensor has an accuracy of +/- 3°C over a range of -20°C to
125°C. SMBUS temperature sensor is not reported in NVMe Health
Log.
Drive provides out-of-band access to temperature by means of
SMBUS.
Note -
For specific site planning guidelines and best practices, refer to the server documentation
and product notes for your server. Refer to the system site planning guide, if available.
