Driver Parameters (Oracle Solaris x86)
You can configure these parameters on each
bnxt interface.
Jumbo frames
default_mtu=mtu
Size of the default MTU (payload without the
Ethernet header). Allowed values:
1500 to 9500
(default = 1500)
Flow control
flow_control
Ethernet flow control. Allowed values:
0 - Disable (default in Oracle Solaris
11)
1 - Receive only
2 - Transmit only
3 - Receive and transmit
Transmit queue size
tx_ring_size
Number of the transmit descriptors per transmit queue. The actual
value is rounded up to the next multiple of 8. Allowed
values:
64 to 4096
(default = 1024)
Receive queue size
rx_ring_size
Number of the transmit descriptors per receive queue. The actual
values:
64 to 4096
(default = 1024)
