Go to main content
Oracle® Dual Port 25 Gb Ethernet Adapter User's Guide
Exit Print View
Updated: June 2019
VLANs Overview
Virtual LANs enable you to divide the network into subnetworks without having to add to the physical network environment. The subnetworks are virtual and use the same physical network resources. VLANs facilitate network administrations because the smaller groups are easier to maintain.
You can create VLANs according to various criteria, but each VLAN must be assigned a VLAN tag or VLAN ID (VID). The VID is a 12-bit identifier between 1 and 4094 that identifies a unique VLAN.
Note - If you configure a VLAN virtual device for an Ethernet adapter, all traffic sent or received by that Ethernet adapter must be in VLAN-tagged format.
Related Information
