| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2017, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
You can send messages by clicking Share on the menu toolbar (shown in Figure 3-2). Alternatively, you can send messages by choosing File on the application-level menu. For more information, see "Emailing, Faxing, Paging, and Sending Outbound Wireless Messages".
Figure 3-3 shows the options for sending messages.
After you click Share on the menu toolbar, the following icons appear:
Email messages. Click to send email messages. On some screens, the Pick Recipient dialog box might appear. After you select a recipient in the Pick Recipient dialog box, and click OK, the Send Email dialog box appears. You prepare the email message in this dialog box, and then click Send. For more information, see "Sending Email from Applications".
Faxes. Click to send faxes. On some screens, the Pick Recipient dialog box might appear. After you select a recipient in the Pick Recipient dialog box, and click OK, the Send Fax dialog box appears. You prepare the fax in this dialog box, and then click Send.
Pages. Click to send pages. The Send Page dialog box appears. You prepare the page in this dialog box, and then click Send.
Outbound wireless messages. Click to send outbound wireless messages. On some screens, the Pick Recipient dialog box might appear. After you select a recipient in the Pick Recipient dialog box, and click OK, the Send Wireless Message dialog box appears. You prepare the outbound wireless message in this dialog box, and then click Send.
