| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2017, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
Your organization determines the screens that appear in the application window. These screens might be only a subset of the available screens. You access a screen by clicking Side Menu on the application banner (shown in Figure 3-2), and then selecting the screen name from the list of screen names. You can also use the Site Map to access the screen.
If the screen name that you want does not appear in the list of screen names for the Side Menu, then you can show that screen name with the other screen names so that you can easily access the screen. For more information about specifying the screens that appear in your Siebel application, see "Showing, Hiding, and Reordering Screens or Views".
To see a list of all the screens available to you, use the Site Map as shown in the following procedure.
To navigate to a screen using the Site Map
Do one of the following:
From the application-level menu, choose Navigate, then Site Map.
Click Site Map on the application toolbar (shown in Figure 3-1).
(Optional) To restrict the hyperlinks that appear in the Site Map, enter appropriate text in the field for searching.
In the Site Map, click the hyperlink for the screen you want to navigate to.
The Site Map displays the screen name and all the view names available in that screen.
Click a hyperlink to navigate to the screen or view.
