| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.6 E93319 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to make the trial UTILITY generic program load (GPL) the approved UTILITY GPL.
The UTILITY GPL cannot be loaded and run from the removable cartridge like the other GPLs. The approved version of the UTILITY GPL is on the fixed disk. The trial version of the UTILITY GPL is located on the removable cartridge or removable media. This procedure loads the trial UTILITY GPL from the removable cartridge to the fixed disk and makes it the approved UTILITY GPL.
The removable cartridge or removable media that contains the UTILITY GPL to be loaded on to the EAGLE is required.
When the UTILITY GPL is displayed with the rtrv-gpl command, the entry CDU appears in the GPL column of the rtrv-gpl output.
Figure 3-6 Making the Trial Utility GPL the Approved Utility GPL
Sheet 1 of 3
Sheet 2 of 3
Sheet 3 of 3
