Resource Assignments window
Use the Resource Assignments window to view all resource assignments for all currently opened projects. You can also display resource cost and quantity information in a spreadsheet. You can group, sort, and filter resource assignments, customize columns, and open and save resource assignment layouts.
To display the Resource Assignments window, do one of the following:
Refer to the following sections of this topic for information and links to concepts and tasks about working with assignments in the Resource Assignments window:
Working in the Resource Assignments window
When working in the Resource Assignments window, you can:
When filling data down or across, consider the following:
Tips
When connected to a P6 EPPM database: The following applies when you filter by a unit or duration field (associated with activity data) from the Resource Assignments window: If the Use the assigned calendar to specify the number of work hours for each time period checkbox is cleared (Application Settings in P6), then filtering applies the unit or duration value based on the Application Settings in P6 hours per time period settings.
If the checkbox is marked, then filtering applies the unit or duration values as follows: For a task-dependent activity, duration or unit values are applied based on the applicable global or project calendar; for a resource-dependent activity, duration or unit values are applied based on the resource calendar.
Note
Resource assignment concepts
Resource assignment tasks
You can perform most tasks related to resource and role assignments in the Activities window. For example, you can assign resources and roles to activities in the Activities window and define details for each assignment on the Resources tab of Activity Details.
You can use the Resource Assignments window to view resource allocations across all open projects and customize the display of assignments according to your preferences. In Assignment Details, you can change the resource or role assigned to an activity, assign cost accounts to assignments, identify an assignment's primary resource, select the rate type for assignments, edit budgeted or planned, actual, and remaining unit values, and edit original or planned and remaining durations.
You can also perform the following tasks:
Related Topics
Project Toolbar
Top Layout Toolbar
Menu bar
Layout Toolbar
Resource Assignments Details
Bottom Layout Toolbar
Future period bucket planning
Introduction to Resource Security
Current Project Resources
Leveling resources
Calendars
Calculating cost when using multiple resource rates
Activities
The Resource Usage Spreadsheet
Roles
Resources
Resource curves
Recalculating assignment costs
Activities Window
Assign a curve to a resource or role assignment
Create a future period bucket planning layout
Customize Resource Usage Spreadsheet columns
Display the Resource Usage Spreadsheet
Group and sort Resource Usage Spreadsheet columns in the Resource Assignments window
Manually enter future period assignment values
Remove a curve from a resource or role assignment
Resize the panes of the Resource Usage Spreadsheet
Save a layout in the Activities or Resource Assignments window
View a spreadsheet of resource allocation for a specific project
Select Resource Usage Spreadsheet fields
Copyright © 1999, 2020
Last Published Friday, October 1, 2021
