Go to primary content
Oracle® Communications EAGLE Application Processor Alarms and Maintenance Guide
Release 16.3
E96331
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
6000000000000001 - RMTP Channel A Down
Channel A of the IP multicast mechanism is not available.
Recovery
  1. Check the physical connections between the local EPAPs, and the EPAPs and the Service Module cards on the EAGLE. Make sure that the connectors are firmly seated.
  2. Run syscheck (see Running the System Health Check)
    If you cannot log in, go to 3.
  3. Perform Restarting the EPAP Software.
  4. Capture the log files on both EPAPs (see Saving Logs Using the EPAP GUI”)
  5. Contact My Oracle Support (MOS).
