| Oracle® Communications EAGLE Application Processor Alarms and Maintenance Guide Release 16.3 E96331 |
![]() Previous |
![]() Next |
Alarm Type: TPD
Description: This alarm is generated by the MPS syscheck software package and is not part of the TPD distribution.
If these three alarms exist, the probable cause is a failed mate server.3000000000000200-Server Eagle Network A Error
3000000000000400-Server Eagle Network B Error
3000000000000800-Server Sync Network Error
One or both of the servers is not operational.
One or both of the switches is not powered on.
The link between the switches is not working.
The connection between server A and server B is not working.
The eth01 interface (top ethernet port on the rear of the server A) connects to the customer provisioning network.
The eth02 interface (2nd from top ethernet port on the rear of the server A) connects to port 3 of switch A.
The eth03 interface (2nd from bottom ethernet port on the rear of the server A) connects to port 3 of switch B.
The eth04 interface (bottom ethernet port on the rear of the server A) is an optional connection to the backup customer provisioning network.
The interfaces on the switch are ports 1 through 20 (from left to right) located on the front of the switch.
Ports 1 and 2 of switch A connect to ports 1 and 2 of switch B.
Ports 5 through 21 of switch A can be used for links to the Main SM ports (SM A ports) on the EAGLE.
Severity: Major
OID: 1.3.6.1.4.1.323.5.3.18.3.1.2.10
Alarm ID: TKSPLATMA103000000000000200
Recovery
