Work with Order Screen in Order Maintenance
Purpose: You use this screen in both order entry and order maintenance.The updates you can perform in order maintenance, including any conditions or restrictions, are described in Field Updates. See Entering Orders for field descriptions.
Quote maintenance activities: See Maintaining Quotes in Order Maintenance for more information on the maintenance activities you can perform on a pre-order quote.
Retail pickup or delivery orders: See Maintaining Retail Pickup or Delivery Orders from the Order Broker for a discussion on maintaining these orders.
Oracle Retail Customer Engagement customer integration: When you use the Oracle Retail Customer Engagement customer integration, if you update the customer’s name or address information in order maintenance, Order Management System sends an update to Oracle Retail Customer Engagement so that the customer records in the two systems are synchronized. See the Customer Engagement Customer Integration for more information.
How to display this screen:
• Select an order through the Order Maintenance Selection Screen or a subsequent scan screen.
• Select Maintain at the Order Inquiry Header Screen or Order Inquiry Detail Screen.
• Select Maintain on the Third Streamlined Order Inquiry Screen (Order Summary) in Streamlined Order Inquiry (DORI).
This table identifies the fields on the Work with Order screen that you can change, and discusses the conditions and restrictions for updating these fields, if any. A restriction is an action that the program allows or does not allow. A condition is a situation under which a certain action is allowed. The condition or restriction column is blank for a field if you can update the field under any condition.
Field Update |
Result |
Condition or Restriction |
The system places the entire order on hold; the order is not eligible for pick slip preparation when you enter a user-defined hold code. |
You can set authority to release an order from hold at the user or user class level. This can be a blanket authority for all order hold reasons, or can be specific to individual reason codes. See Establishing Order Hold Reason Codes (WOHR). You cannot set authority on placing on order on hold, only releasing. |
Calc freight |
The system suppresses all freight charges for new items (including freight and additional freight) when you deselect this field. If service charges by ship via would normally apply, the system suppresses these as well. |
Conditions: The system does not calculate freight for new items you add to the order when this field is unselected; the system charges the customer any freight previously calculated for existing order detail lines if using a line-level freight method. The Recalculate Freight Default (F62) system control value controls the default setting of this field. |
Attention |
The system prints/does not print an attention line on the pick slip when you enter or delete a name in this field. |
Changes to this field are not sent to Order Broker. |
The system updates the Sold-to Customer record automatically when you change this value. A value of N indicates that the customer does not want to receive catalog mailings; use this to exclude this customer from any house lists you generate. |
Rent |
The system updates the Sold-to Customer record automatically when you change this value. A value of N indicates that the customer does not want you to sell his or her name to other companies for their mailing lists; use this to exclude this customer from any house lists you generate. |
Name and Address |
The system updates the Sold-to Customer record automatically when you change any customer address information, including: the prefix or suffix, first, middle, or last name, company name, street address, postal code, city, state, country, delivery code, day or third (fax or mobile) telephone number. The system revises the Sold-to customer's match code based on the changes to the name and address. |
Sold To/Bill To Link A pop-up window displays when the Sold-to customer is linked to a permanent Bill-to account. The window allows you to apply the changes made to the Sold-to address to the Bill-to address as well. See Display/Update Bill to Screen. Tax and Freight Recalculates the tax and freight on the order. VAT and Tax-Inclusive Pricing If changing the shipping address on the order affects whether the order is subject to VAT and tax-inclusive pricing, the system will reprice any open lines based on this change. For example, if you have set up an offer price for an item of $1.00, and a tax-inclusive offer price of $1.50, this item will be repriced from $1.00 to $1.50 if you change the shipping address from a VAT-exempt state to a non-VAT-exempt state. This repricing does not take place automatically for any line with a price override reason code, including incentive items, promotional items., etc. See Setting Up Order Entry Values for more information on VAT and tax-inclusive pricing. Order Broker Interface If you change these fields in the shipping address for an order which includes an open drop ship PO line processed through the Order Broker Drop Ship Manager interface, Order Management System sends the updated address information to Order Broker. |
Shipping restrictions: If one or more items on the order is restricted from being shipped to the state or country of the ship to address, a message indicates: One or more items on the order line are restricted to new Shipping country/state. See Entering Additional Item Information, for information on item/state restrictions. |
M/F |
The system updates the Sold-to Customer record automatically when you change this value. A value of M indicates that the customer is male; a value of F indicates that the customer is female. |
Delivery |
The system uses a different rate table to calculate shipping charges if U.P.S. is the shipper when you change this value to/from business) or residence. A third value, no distinction is valid only for shippers other than U.P.S. The system updates the Sold-to Customer record automatically when you change this value. |
Condition: The value in the Delivery field applies only to shippers that use rate tables to calculate shipping charges, such as UPS. Restrictions: You cannot change this value to No Distinction if U.P.S. is the shipper. (The system identifies the shipper as U.P.S. if the Type field in the Ship Via table is unselected. See Working with Ship Via Codes (WVIA) for more information.) |
Phone numbers |
The system updates the Sold-to Customer record automatically when you change these values. |
Restriction: You cannot delete all phone numbers if the system control value Require Phone Number in Order Entry/Order Maintenance (H01) is selected. Order Broker Interface If you change the Day or Primary phone field for a sold to or ship to address on an order which includes an open drop ship PO line processed through the Order Broker Drop Ship Integration, Order Management System sends the updated address information to the integrated system. |
Email address |
OptIn |
Customer class |
Conditions: Required? The Require Customer Class in OE, WCAT, and WCST (H85) system control value defines whether this field is required. Restrictions: Secured? The Maintenance of Customer Class Field (B07) secured feature defines whether you can enter or maintain the customer class field at this screen. Note: If the Require Customer Class in OE, WCAT, and WCST (H85) is selected and the customer does not have a customer class code assigned, a user who does not have authority based on the Maintenance of Customer Class Field (B07) secured feature will not be able to maintain the order. |
Source |
The system deletes the dollars and number of units posted to the original source code and posts this information to the new source code. |
Conditions: You cannot change the source code if any shipments have been made on the order. Restrictions: The source code override at the order header level must use the same freight and pricing methods. The system does not update the source code at the detail line level when you update the source code on the order header. |
Salesrep# |
The system updates sales reports based on your entry of a different sales representative number. New items are booked to the new sales representative number. |
Sales representatives are defined in and validated against the Salesman table. See Working with Sales Representatives (WSLS). Restrictions: The Maintain Sales Rep # During Order Maintenance (B22) secured feature controls whether you can update the Salesrep field on the Work with Order screen in Order Maintenance. If you do not have authority to this secured feature, the Salesrep field is display-only. |
Ship via |
All open (unshipped) items ship by the new shipper. A pop-up window opens confirming whether you want to recalculate freight charges for the order. Note: If you change to an express bill Via, you must manually authorize active credit card pay methods. Reviewing eligible ship vias and optionally selecting an override You can prompt on this field to advance to the Valid Ship Vias for Window, where you can review valid ship vias for the order, including their overall shipping charges and expected delivery dates; optionally, you can select an override ship via. |
Condition: All open (unshipped) items ship by the new shipper. Restrictions: The shipper update on the order header screen affects all items except those with a ship via override. Express bill: You cannot change the ship via to an express bill shipper if any order lines are reserved, or if there is a printed drop ship item. Item ship via override: If item ship via overrides exist, the system verifies that the new shipper is eligible to ship the open items remaining on the order. If the new shipper is not eligible to ship an item on the order, the Ship Via Overrides for Item Window displays, requiring you to select a valid shipper for that item. See Working with Item Ship Via Overrides for more information on defining item ship via overrides. Best way shipper: If you change the ship via to the Best Way Ship Via for Auto-Assignment (J67) and the Display Alternate Shipping Charges by Via Window in OM (I02) system control value is set to Y, the system assigns the “best way” ship via with the lowest overall shipping charges to the order. See the Best Way Ship Via for Auto-Assignment (J67) system control value for more information. Van delivery shipper: If you change the ship via to the Default Van Delivery Ship Via (L07), the system verifies that the shipping address on the order qualifies for van delivery. If the order ship to does not qualify for van delivery, the system displays an error message and requires you to enter another ship via code: Van delivery ship via not allowed. See Van Delivery Processing for an overview. |
Gift |
When you select this field, you are prompted to enter the shipping address of the gift recipient. The system suppresses prices on the pick slip for open (unshipped) items and prints a Gift Acknowledgment Card for the Sold-to customer when the gift order ships. |
Condition: The prices for all open (unshipped) items do not print on the pick slip if this field is selected. |
Priority |
Entry of a different reservation priority changes the priority of open (unshipped) items on this order for backorder or order reservation. |
Condition: All open (unshipped) items are assigned this reservation priority. The reservation priority is used only by the Evaluate Backorders program and does not affect the Immediate Reservation program. |
Warehouse |
If you add or change the warehouse, the system: • Applies the new warehouse code to each open line on the order. • Removes the existing inventory reservations for the open order lines on the order that do not contain a printed quantity. • Attempts to reserve the items on the order in the new warehouse specified. If an item is not available in the warehouse specified, the system assigns this warehouse as the backorder warehouse for the unreserved quantity of the item on the order line. |
Condition: If you change the warehouse code on the order header so that it no longer qualifies for van delivery, the system requires you to remove the Default Van Delivery Ship Via (L07) if it is defined on the order header. See Van Delivery Processing for an overview. |
If you remove the warehouse, the system: • Removes the warehouse code assigned to each open line on the order. • Removes any existing inventory reservations for the open order lines on the order that do not contain a printed quantity. • Attempts to reserve the items on the order using regular reservation logic. |
Condition: If you remove the warehouse code on the order header, the system requires you to remove the Default Van Delivery Ship Via (L07) if it is defined on the order header. |
Associate |
Updating to Controls whether the customer is eligible for associate (member) pricing discounts on new items on the order. The system updates the Sold-to Customer record automatically when you change this value. |
Condition: If you select this value, only new items are eligible for associate pricing. Restrictions: The Change Associate Customer Flag (B10) secured feature controls whether you can change this setting; if you prohibit access to this feature, the system displays an error message if you try to change the value: Not authorized to change Associate Customer. |
Discount % |
Entering a discount percentage instructs the system to apply a merchandise discount against discountable items that you add to the order. The discount is not applied to existing items. |
Condition: Only new items are eligible for the discount percentage. |
Est frt |
You can enter an estimated freight charge for inquiry purposes only if you change the source code to one that uses the Actual (A) freight method. |
Auto can B/O |
Indicates whether the system automatically cancels any backordered items after the first shipment. The system cancels any unshipped lines during Confirmation. |
Condition: If you select this field, all open (unshipped) items will be canceled. |
Cancel date |
This is the last date on which the customer will accept receipt of this order. Orders still open on this date are printed on the Order Cancellation list; Customer Service uses this list to contact the customer and, if necessary, cancels the order through Order Maintenance. |
Condition: If you enter a date in this field, only open (unshipped) items will be affected by the cancel date. |
Arrival date |
This is the date on which the customer wants to receive this order. |
Restrictions: The system updates each open (unshipped) item on the order automatically with the new arrival date. |
Tax code |
This code controls the taxable status of the order. |
Conditions: The new tax code controls how the system calculates tax only for new item additions to the order. |
Tax identification |
The system requires a tax identification number if the Tax code is set to reseller (R) or exempt (E); otherwise, optional. |
PO# |
Screen Option |
Procedure |
Work with items on the order |
Select Detail to advance to the Work with Order Lines Screen. |
Work with payment methods on the order |
Select Pay Methods to advance to the Enter Payment Methods Screen in Order Maintenance. |
Add or change a customer ship to for the order |
Select Ship To to advance to the Change Customer Ship To Screen (Using, Changing, or Excluding a Shipping Address), the Select Customer Ship To Window (Scanning for a Shipping Address), or the Create Customer Ship To Screen, depending on whether a ship-to customer already exists for the sold-to customer or the order. |
Work with the bill-to customer for the order |
Select Bill To to advance to the Select Customer Bill To Window, Create Customer Bill To Screen, or the Change Customer Bill To Screen (Selecting, Changing, or Excluding a Billing Account), depending on whether a bill-to customer already exists for the sold-to customer or the order. |
Review or work with order messages |
Select Messages to advance to the Work with Order Messages Screen. |
Accept or reject your changes to the order |
Select Accept Order to accept your changes to the order, or select Reject Order to exit the order without saving your changes. See Order Maintenance Processing for information on the updates the system performs when you Select Accept Order. |
Accept the changes to the order and add a recipient customer |
Select Add Recipient to accept the changes to the order and enter or select a new order recipient. See Adding a Recipient Order in Order Maintenance. |
Review or work with an order-level ship-to address |
Select One Time Ship To to advance to the Change or Create One Time Ship To Address Screen. |
Alternate between the sold-to customer’s and the recipient’s name and address |
Select Sold To/Recipient to clear the current customer’s information from the screen and display the recipient’s information. See Alternating Display of Sold-to/Recipient Addresses. |
Cancel the entire order |
Select Cancel Order to display the Enter Cancel Reason Window. For regular orders, see Canceling an Order through Order Maintenance. For quotes, see Cancelling a Quote through Order Maintenance. |
Work with or review order-level additional charges |
Select Additional Charges to advance to the Change Additional Charges Screen. |
Work with or review an expanded address |
Select Expand Address to advance to the Expand Name/Address Screen. |
Review additional order options |
Select More Options to advance to the Display More Options Screen. |
Review or work with additional order properties |
Select Properties to advance to the Work with Order Ship to Properties Screen. |
Display a summary of items and order totals |
Select Summary to advance to the Display Order Summary Screen. |
________________________________
Contents SCVs Reports XML Messages Glossary
Copyright © 2022, Oracle and/or its affiliates. All rights reserved.
Legal Notices
