Canceling an Order through Order Maintenance
Purpose: You can cancel an entire order by selecting Cancel Order on the Work with Order Screen in Order Maintenance or the Work with Order Lines Screen in order maintenance. The system frees up any reserved inventory on the canceled order and makes it available to other orders.
To cancel an order line: See Canceling an Item in Order Maintenance.
What if the order includes a membership item? See Canceling a Membership Item for information.
Canceling brokered orders: You need authority under the Cancel Order Broker Lines (B19) secured feature to cancel a retail pickup, delivery, or store pickup order, or an order that includes a brokered backorder line. For an overview, see Order Broker Integration, including:
• Canceling a Brokered Backorder Request
• Retail Pickup (including Ship-for-Pickup) or Delivery Orders
• Canceling a Store Pickup Order
Canceling a retail pickup or delivery order: If you cancel a retail pickup or delivery order, the system changes the Order Broker record’s status to Canceled and sends a status inquiry request to the Order Broker. If the order’s status in Order Broker is:
• Canceled: the system does not send a status update to Order Broker; otherwise,
• If the order’s status in Order Broker is anything but Canceled, the system sends a status update to Order Broker indicating the status is Rejected. In this situation, the Order Broker then changes the order status to New_order.
Important: If Order Broker is configured to “reshop” (the Search retries setting at the Preferences screen is not set to 0), then in this situation the Order Broker attempts to assign the order to another location for fulfillment.
Canceling a quote through order maintenance: See Cancelling a Quote through Order Maintenance for information.
Cancellation email: The system generates an order cancellation email or Outbound Email XML Message (CWEmailOut) to the customer if:
• you have specified an Order Cancellation Email Program (K78), and
• there have not been any shipments on the order, and
• the cancel reason code you use does not match the Cancel Reason Code to Suppress Email (L08), and
• the customer is eligible to receive email notifications; see When Does the System Generate an Email Notification?
If there have been any shipments on the order, the system generates the order line cancellation email even if all the remaining order lines are now canceled.
See the Order Cancellation Confirmation Email Sample and Contents and the Order Line Cancellation Confirmation Email Sample and Contents for more information.
In this topic:
• Order Updates for Cancellation
To cancel: Select Cancel Order at the Work with Order Screen in Order Maintenance or Work with Order Lines Screen to display the Confirm Cancel window. If you select OK at this pop-up window, you advance to the Enter Cancel Reason window.
Field |
Description |
Order # |
The number of the order you wish to cancel. Numeric, 9 positions; display-only, assigned by the system. |
Ship to number (Unlabeled field to the right of the order number) |
The number of shipping addresses for the order you wish to cancel. Numeric, 3 positions; display-only, assigned by the system. |
Cancel reason |
The reason for canceling the entire order. Cancel reason codes are defined in and validated against the Cancel Reason table; see Establishing Cancel Reason Codes (WCNR). Numeric, 2 positions; required. |
Cancel all ship to's |
Controls whether the system cancels each recipient order or only the current order. A recipient order is an order that is shipping to a different address. Valid values are: • Selected = Cancel all recipient orders. • Unselected = (default) Cancel only the current order. Note: If the Submit O/M Cancel Asynchronously (M36) system control value is selected, the Cancel all ship-tos field does not display on the Enter Cancel Reason window and the setting defaults to selected. |
Recalculate freight |
Determines whether the system refunds the freight charge to the customer for the canceled items. Valid values are: • Selected =Recalculate and refund freight. The system will recalculate freight down to zero. • Unselected (default) = Do not recalculate and refund freight. The Recalculate Freight Default (F62) system control value controls the default setting of this field, but you can override this default. Tax: The system recalculates tax regardless of the setting of this field. Note: If the Submit O/M Cancel Asynchronously (M36) system control value is selected, the Recalculate freight field does not display on the Enter Cancel Reason window and the setting defaults from the Recalculate Freight Default (F62) system control value. |
When you select OK at the Enter Cancel Reason window to submit the order cancel, the system looks at the setting of the Submit O/M Cancel Asynchronously (M36) system control value.
• If the Submit O/M Cancel Asynchronously (M36) system control value is selected, the system submits the order cancel asynchronously. The system locks the order until the cancel is complete. In addition, the system writes a message to the TRACE log when an asynchronous order cancel starts and when it ends.
• If the Submit O/M Cancel Asynchronously (M36) system control value is unselected, the system submits the order cancel synchronously.
The system performs these updates when you select Cancel Order on the Work with Order Screen in Order Maintenance or the Work with Order Lines Screen in order maintenance, based on whether the cancel reason code you use reduces demand:
Reduce Demand? |
Order Status |
Line Status |
Quantity Ordered |
Quantity Canceled |
no |
Cancelled if you cancel the entire order. Closed if part of the order has already shipped or was soldout. |
Cancelled if you cancel the entire order line. Closed if all or part of the order line has already shipped. Note: Any lines that were previously soldout remain in a Soldout status. |
not affected |
updated with quantity cancelled |
yes |
Closed |
Closed Note: Any lines that were previously soldout remain in a Soldout status. |
decreased by quantity cancelled; 0 displays if the entire line was cancelled |
not affected |
See Establishing Cancel Reason Codes (WCNR) for more information about reducing demand.
The order remains on the system for inquiry purposes; you can reopen a canceled order through Order Maintenance by adding a new item to the order.
You cannot update any canceled lines through Order Maintenance.
Purpose: This window opens when you select Cancel Order to cancel an order that has printed pick slips.
To complete this window: Select Void/Reprint to void the pick slips, or select OK or Exit to cancel. You cannot cancel the order until pick slips are voided.
If you select Void/Reprint, you advance to the Reprint/Void Pick Slips by Order Screen. An error message indicates if you are not authorized to void pick slips:
User (SBROWN) is not authorized to void pick slips.
________________________________
Contents SCVs Reports XML Messages Glossary
Copyright © 2022, Oracle and/or its affiliates. All rights reserved.
Legal Notices
