Setting Permissions for Inbox
To set Inbox permissions for Company Workspace and project or shell instances:
  1. Go to the Company Workspace tab and switch to Admin mode.
  2. In the left Navigator, select User Administration, and then select Access Control.
  3. In the right pane, expand User Mode Access, expand Projects/Shells, expand Mailbox, and then expand Project Mailbox.
  4. Click Inbox to open the Permissions Setting for: Inbox window.
  5. Click Add or Modify and grant the following permissions:
    • Delete: To delete messages.
    • Reply: To reply to messages.
    • View: To view messages.
    • Create/Manage Folders: To create, rename, and move folders under Inbox.
  6. Click Apply when finished.
    Note: You cannot grant permissions at Project Mailbox level. All Project Mailbox permissions must be granted at Inbox level.
For Permission Templates:
  3. In the right pane, expand Administration Mode Access, and then expand Standards & Libraries.
  4. Click Permission Templates to open the Permission Settings for: Permission Templates window.
  5. Click New.
  6. Click Permissions.
  7. Go to User Mode Access and expand it.
  8. Click Mailbox to expand it.
  9. Click Project Mailbox to expand it.
See Also
User Administration
Owner Company or Sponsor Company
Partner Company or Member Company
Editing User Permissions at Company, Shell, and Project Levels
Adding and Managing Company Users
Creating Partner Companies and Users
Adding and Managing Partner Company Users
Adding and Managing Groups
Integration Users
Managing Users in Bulk
Creating and Managing User Preference Templates
Creating and Maintaining an Approved Email List for Project or Shell Mailboxes
Updating the Email Address for a Project or Shell
Importing and Exporting Email Addresses
Managing Permissions and Access Control
Announcements Node
Working with the License Manager
Running System Usage Reports
Setting Permissions for Unpublished Attachments
Task Reassignment (Company and Project)
Last Published Tuesday, April 15, 2025
