Permissions for Oracle Primavera Cloud Integration Settings
The Unifier Essentials Company Administrator is someone who will be able to configure (edit) or view the Primavera Cloud integration settings and the cash flow data source configurations. A Company Administrator who has the Configure permission can configure the source application connection and the cash flow project data sources.
The permissions for accessing the Primavera Cloud functional node is set within the Access Control functional node (go to the Company Workspace tab and switch to Admin mode; in the left Navigator, select User Administration, and then select Access Control). The permission settings for the Primavera Cloud are: Configure and View.
- A user with Configure permission can configure the source application connection and cash flow project data sources.
- A user with View permission can configure the integration settings.
To assign permissions to the Oracle Primavera Cloud functional node:
- Go to the Company Workspace tab and switch to Admin mode.
- In the left Navigator, select User Administration, and then select Access Control.
- In the right pane, expand Administration Mode Access, expand Integrations, and select Primavera Cloud to open the permission settings window and assign the appropriate permissions.
To access the Oracle Primavera Cloud node:
- In the left Navigator, select Integrations, and then select Primavera Cloud.
See Also
Unifier Essentials and Oracle Primavera Cloud
Integrating Unifier Essentials with Oracle Primavera Cloud Overview
Sending and Receiving Cash Flow Data
Reviewing the Planned Budget and Submitting Results
Oracle Primavera Cloud Integration in Unifier Essentials Company
Oracle Primavera Cloud Integration in Unifier Essentials Shell
Oracle Primavera Cloud Integration and Unifier Essentials Cash Flow (User Mode)
Oracle Primavera Cloud Integration in Company Sponsored Shells
Receiving Data from Primavera Cloud Project Cash Flows
Unifier Essentials and Oracle Integration
Integrating a System Activity Sheet or Master Rate Sheet through Oracle Integration
Last Published Tuesday, April 15, 2025
