Setting Up PeopleSoft Project Costing for PeopleSoft Commitment Control
Pages Used to Set Up PeopleSoft Project Costing for PeopleSoft Commitment Control
General Ledger Integration Page
PROJ_INT_TMPL_03
Select the Primary Ledger Business Unit check box to designate the integration template as the primary general ledger business unit that is used for budget creation and budget checking when this integration template is specified for a project.
Application Fundamentals: Installation Options - Project Costing Page
INSTALLATION_PC
In the Analysis Groups Default group box:
  • Select an analysis group from the Cost Budget drop-down list box.
    The default value is BUD.
  • Select an analysis group from the Revenue Budget drop-down list box.
    The default value is RBUD.
Analysis Types Page
PROJ_ANTYPE_DEFN
Designate a Commitment Control amount type for the analysis types that will be used for Commitment Control budget checking.
Project Costing Definition Page
PROJECT_GEN_01
If necessary, override the default budget analysis group by selecting different analysis types that identify a budget.
In the Grants group box, specify if the project is grant funded. The Grants group box is visible only if PeopleSoft Grants is installed and you access the Project Costing Definition page by using the Grants, and then Awards, and then Establish Project General Infoportal navigation.
Related Topics
Analysis Types Page
Use the Analysis Types page (PROJ_ANTYPE_DEFN) to designate a Commitment Control amount type for the analysis types that will be used for Commitment Control budget checking.
Navigation:
Setup Financials/Supply Chain, and then Product Related, and then Project Costing, and then Transaction Options, and then Analysis Types, and then Analysis Types
Field or Control Description
Commitment Control Amount Type
To set up Commitment Control analysis types, select a Commitment Control Amount Type value to identify how transactions of this analysis type are used in Commitment Control budget checking.
Source Transaction Type
Displays either the PC_JOURNAL or PC_BUDGET transaction type that is defined in the Commitment Control feature. The source transaction type maps PeopleSoft Project Costing fields to Commitment Control fields.
This table lists the delivered analysis types and amount types that are used for Commitment Control:
Analysis Type Commitment Control Amount Type Commitment Control Ledger Group Type
REQ
Pre-Encumbrance: Designates requisitions.
Expense
CRQ
Pre-Encumbrance: Designates cost sharing requisitions.
Expense
COM
Encumbrance: Designates purchase orders.
Expense
ACT
Actuals and Recognized: Designates actual cost expenses for expense type ledger groups and recognized revenue for revenue type ledger groups.
Expense
Revenue
Related Topics
