Performing Position Management Tasks as an Administrator Using Fluid
This topic discusses prerequisites to using fluid Position Management and lists the pages that administrators can access from a single location in the PeopleSoft Fluid User Interface to perform position management-related transactions.
For general information about fluid pages in PeopleSoft HCM, see Application Fundamentals: Understanding PeopleSoft Fluid User Interface Homepages.
The following videos provide an overview of Fluid Position Management:
Video: PeopleSoft Fluid Position Management
Video: Image Highlights, PeopleSoft HCM Update Image 29: Fluid Position Management
Pages Used to Manage Positions as an Administrator Using Fluid
| Page Name | Definition Name | Usage |
HC_HR_POS_MANAGEMENT_FL (this is the cref for this tile) |
Access the Position Management dashboard where you can set up or view summaries of Position Management data. |
PT_LANDINGPAGE |
Access Position Management-related tiles and pages. |
Prerequisites to Using Fluid Position Management
In order to access and use the fluid Position Management pages, the following steps must be performed first:
Assign the Manage Positions Fluid (HCCPHRFL3100) permission list to the administrator role managing positions. This permission list grants users access to these pages and objects using the PeopleSoft Fluid User Interface:
Manage Position
Position View Details
Related Information
The guided processes menu: Grouplets, My Preferences, and My Personalizations
Enable Fluid Position Management on the Position Data Installation Page.
To allow administrators the ability to delete position data rows through the fluid Position Data component, assign the Position Delete Administrator role to the user.
Synchronizing Position Management Data
PeopleSoft Position Management provides the Application Engine POS_SYN_FLU to synchronizes the data from your existing position management data to the new records using the effective sequence.
To carry forward the customized data from your existing Position Management system, you need to add the custom fields and validations to the effective sequence component.
Position Management Tile
Use the Position Management tile to access the Position Management dashboard where you can set up or view summaries of Position Management data.
Navigation:
The Position Management tile is delivered as part of the Workforce Administrator home page, but the location can change if you change the delivered home pages or if administrators personalize their home pages.
This example illustrates the fields and controls on the Position Management tile.
Click the Position Management tile to access the Position Management Dashboard, where you can perform the task of creating, updating, or viewing summary information about positions.
Related Topics
Use the Position Management dashboard (PT_LANDINGPAGE) to access Position Management-related tiles and pages.
Navigation:
Click the Position Management Tile, which is delivered as part of the Workforce Administrator home page, but the location can change if you change the delivered home pages or if administrators personalize their home pages.
This example illustrates the Position Management dashboard.
This Position Management dashboard enables administrators to access frequently-used Position Management components from one location.
Use the links in the table to access complete documentation for each tile transactions.
| Tile Name | Usage |
Create and manage positions using the fluid pages. |
View current and historical summary information, including incumbent history using the following classic pages: |
Manage primary incumbent information for a position. |
Access and view position management analytics. |
