4.388 rept-imt-info
Use this command to display the following statistics:
  • IMT bus error statistics currently stored in the IMT fault isolation hourly statistics
  • Current IMT bus use statistics. Bus use is the percentage of the capacity of the IMT bus that is used for data during a particular time.
  • MUX card error statistics
Parameters
report (mandatory)
The type of report that is generated.
Range:
err
hmuxerr
HMUX card error statistics
hiprerr
HIPR card error statistics
hipr2err
HIPR2 card error statistics
ebucket (optional)
End bucket. The last one-hour time period (bucket) for which error statistics are reported.
Range:
0 - 15
Default:
If sbucket is specified—current sbucket value; information for only that time period is displayed.
If sbucket is not specified—15, the report includes statistics for all 16 time periods
eloc (optional)
End location. Specifies the card location of the last card in the range for the report.
Range:
1101 - 1113, 1115, 1201 - 1218, 1301 - 1318, 2101 - 2118, 2201 - 2218, 2301 - 2318, 3101 - 3118, 3201 - 3218, 3301 - 3318, 4101 - 4118, 4201 - 4218, 4301 - 4318, 5101 - 5118, 5201 - 5218, 5301 - 5318, 6101 - 6118
Default:
If sloc is specified—current sloc value; displays information for one card
If sloc is not specified—1115, which corresponds to IMT address 251 (e=251); displays information for entire range of locations.
erronly (optional)
This parameter filters the output to display only non-zero counts in the error report.
Range:
yes
no
Default:
yes
eshelf (optional)
The end shelf location for MUX statistics. This shelf location is the last shelf in the range.
Range:
1100, 1200, 1300, 2100, 2200, 2300, 3100, 3200, 3300, 4100, 4200, 4300, 5100, 5200, 5300, 6100
Default:
sshelf is specified—the report starts with the sshelf value
sshelf and eshelf are not specified—the report is generated for all shelves equipped with the specified MUX type
eslot (optional)
The end slot location for MUX statistics for the cards in the MUX shelf.
Range:
1 - 18
Default:
sslot is specified—current sslot value
sslot is not specified—no default
mode (optional)
The display mode used in the error report.
Range:
full
Displays information for each card along with a summary report
stats
Displays only individual card statistics
summary
Displays the summary portion of the report
Default:
summary
sbucket (optional)
Start bucket. The first one-hour time period (bucket) for which error statistics are reported.
Range:
0 - 15
Default:
0
sloc (optional)
Start location. The card location of the first card in the range for the report.
Range:
Default:
eloc is specified—current eloc value
eloc and sloc are not specified—displays information for entire range of card locations
sshelf (optional)
The starting shelf location for MUX statistics. This location is the first shelf in the range.
Range:
Default:
eshelf is specified—current eshelf value
eshelf and sshelf are not specified—report is generated for all shelves equipped with the specified MUX type
sslot (optional)
The starting slot location for MUX statistics for the cards in the MUX shelf.
Range:
1 - 18
Default:
eslot is specified—current eslot value
eslot is not specified—no default
trm (optional)
The serial port (printer location) where the report is sent.
Range:
1 - 16
Default:
Report displays on the terminal where the command is issued
Example
rept-imt-info:report=err
rept-imt-info:report=err:sloc=1101:eloc=1102:mode=stats
rept-imt-info:report=err:sloc=1101:eloc=1102:mode=full:erronly=no
rept-imt-info:report=hiprerr:sbucket=0
rept-imt-info:report=hiprerr:sshelf=1100:sslot=1:eslot=2:sbucket=0
Dependencies
No related IMT command can be in progress when this command is entered. Only one report can be active at a time.
This command cannot be entered at a telnet terminal (terminal ID 17-40).
This command cannot be entered during an IMT statistics collection period following an hourly boundary (IMT performance monitoring).
The ending hourly time period cannot be less than the starting hourly time period.
If the sslot and eslot parameters are specified, then the sshelf parameter must be specified and the eshelf parameter cannot be specified (slot information is reported for a single shelf).
A value of hmuxerr, hiprerr, or hipr2err must be specified for the report parameter before the sshelf and eshelf parameters can be specified.
The MUX card slots (09 and 10) cannot be specified for the sslot and eslot parameter values.
A card location that is valid and defined in the database must be specified.
This command cannot be entered during an Extended Bit Error Rate Test (BERT).
The shelf locations specified by the sshelf and eshelf parameters must be provisioned in the frame.
The report=err parameter must be specified before the erronly and mode parameters can be specified.
The sshelf parameter must be specified, and a value of hiprerr or hipr2err must be specified for the report parameter before the sslot and eslot parameters can be specified.
A value of hiprerr, hipr2err, or hmuxerr must be specified for the report parameter before the sshelf or eshelf parameter can be specified.
Notes
This command can be canceled using the F9 function key or the canc-cmd command. See canc-cmd for more information.
Hourly Bucket Statistics
Hourly Bucket Statistics apply to cards on the IMT bus and to MUX cards. Each hourly time period (bucket) contains the statistics for a single hour. A total of 16 hourly time periods, numbered 0 - 15, exist. Hourly time period 0 is the most-recent (current), and hourly time period 15 is the least-recent (oldest).
Each hour the statistics for the current hourly time period expire, and the hourly time periods advance. That is, after the advance, the statistics previously reported in hourly time period 0 are now reported in the hourly time period 1, and so on. The statistics reported in the hourly time period 15 are no longer available after the change.
When a card is reinitialized, it begins collecting statistics in hourly time period 0 and changes to hourly time period 1 at the start of the next hour. Thus, the first statistics that a card collects after being reinitialized may be for a partial hour.
MUX Statistics
A MUX card stores the statistics separately for each card on its shelf. If the sloc and eloc parameters are specified, then the card sends the statistics for each card to the OAM application for display. If the sloc and eloc parameters are not specified, then the card sends an aggregate number to the OAM application to represent statistics for all cards on its shelf.
Low Speed Summary
Table 4-43 rept-imt-info Statistics, Low Speed Summary (rept-imt-info:report=(hmuxerr, hiprerr, or hipr2err))
Stat Label – Low Speed Error & Event Counts Explanation of Stat Probable Cause Recommended Action
IMT Rx Packet CRC Error
Receive CRC error: Bad Checksum in received IMT packet. Caused by corrupted data within the received packet.
Detected by hardware.
Maintenance activity: Card insertion, removal, or boot. Does not occur in a normal system and indicates a hardware failure: defective LIM card, MUX card, FC cable or backplane. Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If errors continue, a hardware issue is present. Contact the Customer Care Center.
IMT Rx Packet Format Error
Receive Format error: Occurs when the End of Message byte of an IMT packet is found missing.
Detected by hardware/software.
IMT Rx Violation Error
Violation Error: Received an illegal character from the physical IMT transport (TAXI Interface).
Card insertion, removal, or boot or defective hardware Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If errors continue, a problem may exist. Contact the Customer Care Center.
IMT Rx Command Error Reserved. Reserved. Reserved.
IMT Rx FIFO Full Receive FIFO Full: Watermark indication that this interface receiving data off the TAXI line is receiving traffic in excess of what it can handle. Some traffic will have been discarded. May cause retransmissions, CRC errors and Format errors. Relatively heavy traffic on this interface can cause these counts to increment. If these counts occur in the field, a software problem may exist. Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If errors continue, a problem may exist. Contact the Customer Care Center.
IMT Rx FIFO Half Full Receive FIFO Half Full: Watermark indication that the interface receiving data off the TAXI line has received substantial traffic. Relatively heavy traffic on this interface can cause these counts to increment. None. FIFO Half Full is an indication; no action is required.
IMT Tx FIFO Full
Transmit FIFO Full: The FIFO has overflowed and data has been lost.
This stat is only meaningful for MUX card columns.
Relatively heavy traffic on this interface can cause these counts to increment.  This condition should never occur. These events may indicate a software problem Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If errors continue, a problem may exist. Contact the Customer Care Center.
IMT Tx FIFO Half Full
Transmit FIFO Half Full: Watermark indication that this interface is backed up through ½ of its available storage.
Indicates that data was transmitted at a relatively high rate for a short period. None. FIFO Half Full is just an indication; no action is required.
CPU Rx FIFO Empty Before SOM Occurs when valid packet data is read from the CPU Rx FIFO and the beginning (SOM) of the packet is found missing before all data was read. The SOM was corrupted while being written into the CPU Rx FIFO from the low speed link. None. This error will automatically empty the FIFO so it is ready to continue receiving data. If the error continues, contact the Customer Care Center.
CPU Rx FIFO Empty Before EOM Occurs when valid packet data is read from the CPU Rx FIFO and the end (EOM) of the packet is found missing before all data was read. The SOM was corrupted while being written into the CPU Rx FIFO or a partial packet was written into the FIFO from the low speed link. None. This error will automatically empty the FIFO so that it is ready to continue receiving data. If the error continues, contact the Customer Care Center.
CPU Rx Packet SOM Before EOM A Start of Message was received when an End of Message was expected from the IMT bus. Packet was corrupted in the system (EOM lost) and has another packet appended to it. None. If the problem persists, contact the Customer Care Center.
CPU Rx Packet CRC Error Occurs when valid packet data is read from the CPU Rx FIFO and transferred to the processor memory and calculated CRC does NOT match the CRC word at the end of the packet. The data was corrupted while being written into the CPU Rx FIFO or data coming from the low speed link is corrupted. None. If the problem persists, contact the Customer Care Center.
DMA Terminal Count Received IMT packet length is longer than the max allowed. Detected by hardware. Card insertion/removal or boot. None if card has booted or was just inserted. Clear the stats and if the problem persists, contact the Customer Care Center.
CPU Tx Buffer EOB A packet that was being transmitted from the CPU Tx Buffer did not have an EOM. The data was corrupted while being written into or being read from the FIFO. None. If the problem persists, contact the Customer Care Center.
CPU Tx Buffer Full Transmit Buffer Full: The Tx Buffer unexpectedly filled up. Either the COM software attempted to transmit too much data at once or the Tx logic was unable to transmit the data. None. If the problem persists, contact the Customer Care Center.
CPU Tx Buffer Half Full Transmit Buffer Half Full: Watermark indication that this interface is backed up through ½ of its available storage. Relatively heavy outbound traffic on this interface can cause these counts to increment. None. Buffer Half Full is just an indication, no action is required.
CPU Rx FIFO Full Receive FIFO Full: The Rx FIFO unexpectedly filled up. Indicates that data was received at a higher rate than could be processed by the Communications processor. Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If the errors continue, a problem may exist. Contact the Customer Care Center.
CPU Rx FIFO Half Full Receive FIFO Half Full: Watermark indication that this interface is backed up through ½ of its available storage. Relatively heavy inbound traffic on this interface can cause these counts to increment. None. FIFO half full is just an indication, no action is required.
IMT Bypass FIFO Full IMT Bypass FIFO Full: The bypass FIFO unexpectedly filled up. Relatively heavy traffic on this interface can cause these counts to increment. If these counts occur in the field, a software problem may exist. Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If the errors continue, a problem may exist. Contact the Customer Care Center.
IMT Bypass FIFO Half Full IMT Bypass FIFO Half Full: Watermark indication that this interface is backed up through ½ of its available storage. Relatively heavy inbound traffic on this interface can cause these counts to increment. None. FIFO half full is just an indication, no action is required.
High Speed Summary
Table 4-44 rept-imt-info Statistics, High Speed Summary
Stat Label – High Speed Error & Event Counts Explanation of Stat Probable Cause Recommended Action
IMT Rx Disparity Error Fibre Channel Receive Packet with Disparity Errors: Parity error in received packet. Usually caused by corrupted data. Should not occur in a properly functioning system and may indicate a hardware failure. Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If errors continue, a problem may exist. Contact the Customer Care Center.
IMT Rx Sync Lost Error (This error count is not used in MUX card.)
Fibre Channel Receive Lost Synchronization Errors:
The receiver on this interface lost synchronization.
IMT Rx Code Word Error Fibre Channel Receive code Word Errors: Error in received packet. Caused by corrupted data. Should not occur in a properly functioning system and may indicate a hardware failure. Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If the errors continue, a problem may exist. Contact the Customer Care Center.
IMT Rx Packet SOM Before EOM Fibre Channel Receive Packet with Start of Message without a previous End of Message Errors: The software detected the start of a new packet before the end of the previous packet was detected. Should not occur in a properly functioning system and may indicate a hardware failure. Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If errors continue, a problem may exist. Contact Customer Care Center.
IMT Bypass FIFO Full Fibre Channel Bypass FIFO Full: The FIFO has over run and data has been lost. May result in significant downstream errors. Should not occur in a properly functioning system, and may indicate a software or hardware failure. Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If errors continue, a problem may exist. Contact the Customer Care Center.
IMT Bypass FIFO Half Full Fibre Channel Bypass FIFO Half Full: Watermark indication that this interface has backed up to the half way point of its capabilities. Relatively heavy traffic on this interface can cause these counts to increment. None. FIFO Half Full is just an indication: no action is required.
IMT Rx FIFO Full Fibre Channel Receive FIFO Full: The FIFO has over run and data has been lost. May result in significant downstream errors. Should not occur in a properly functioning system. Indicates a software or hardware failure Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If errors continue, a problem may exist. Contact the Customer Care Center.
IMT Rx FIFO Half Full Fibre Channel Receive FIFO Half Full: Watermark indication that this interface has backed up to the half way point of its capabilities. Relatively heavy traffic on this interface can cause these counts to increment. None. FIFO Full in this case is just an indication; no action is required.
IMT Tx FIFO Full Fibre Channel Transmit FIFO Full: Watermark indication that this interface has transmitted substantial traffic. Relatively heavy traffic on this interface can cause these counts to increment. None. FIFO Full in this case is just an indication; no action is required.
IMT Tx FIFO Half Full Fibre Channel Transmit FIFO Half Full: Watermark indication that this interface has backed up to the half way point of its capabilities. Relatively heavy traffic on this interface can cause these counts to increment. None. FIFO Half Full is just an indication; no action is required.
CPU Rx Fifo Full Receive FIFO Full: The Rx FIFO unexpectedly filled up. Indicates that data was received at a higher rate than could be processed by the Communications processor. Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If the errors continue, a problem may exist. Contact the Customer Care Center.
CPU Rx FIFO Empty Before SOM Occurs when valid packet data is read from the CPU Rx FIFO and the beginning (SOM) of the packet is found missing before all data was read. The SOM was corrupted while being written into the CPU Rx FIFO from the high speed link. None. This error will automatically empty the FIFO so that it is ready to continue receiving data. If the problem persists, contact the Customer Care Center.
CPU Rx FIFO Empty Before EOM Occurs when valid packet data is read from the CPU Rx FIFO and the beginning (SOM) of the packet is found missing before all data was read. The SOM was corrupted while being written into the CPU Rx FIFO or a partial packet was written into the FIFO from the high speed link. None. This error will automatically empty the FIFO so that it is ready to continue receiving data. If the problem persists, contact the Customer Care Center.
CPU Rx Packet SOM Before EOM A Start of Message was received when an End of Message was expected from the Fibre Channel bus. Packet was corrupted in the system (EOM lost) and has another packet appended to it. None. If the problem persists, contact the Customer Care Center.
CPU Rx Packet CRC Error Occurs when valid packet data is read from the CPU Rx FIFO and transferred to the processor memory and calculated CRC does NOT match the CRC word at the end of the packet. The data was corrupted while being written into the CPU Rx FIFO or data coming from the high speed link is corrupted. None. If the problem persists, contact the Customer Care Center.
DMA Terminal Count Received IMT packet length (on Fibre Channel) is longer than the max allowed. Detected by hardware. Card insertion/removal or boot. None if card has booted or was just inserted. Clear the stats and if the problem persists, contact the Customer Care Center.
CPU Tx Buffer EOB A packet that was being transmitted from the CPU Tx Buffer did not have an EOM. The data was corrupted while being written into or being read from the FIFO. None. If the problem persists, contact Customer Care Center.
CPU Tx Buffer Half Full Transmit Buffer Half Full: Watermark indication that this interface is backed up through ½ of its available storage. Relatively heavy outbound traffic on this interface can cause these counts to increment. None. Buffer Half Full is an indication, no action is required.
IXP Rx FIFO Full Fibre Channel IXP Receive FIFO Full: The IXP Rx FIFO momentarily became full. This event can occur under normal conditions and it does not indicate an issue. Relatively heavy traffic on this interface can cause these counts to increase. None. FIFO Full in this case is just an indication; no action is required.
IXP Rx FIFO Half Full Fibre Channel IXP Receive FIFO Half Full: Watermark indication that this interface has backed up to the half way point of its capabilities. Relatively heavy traffic on this interface can cause these counts to increment. None. FIFO Full in this case is just an indication; no action is required.
IMT Rx Byte Per Minute AVG Average per minute Normal behavior None. Information only.
IMT Rx Byte Per Second AVG Average per second Normal behavior None. Information only.
IMT Tx Byte Per Minute AVG Average per minute Normal behavior None. Information only.
IMT Tx Byte Per Second AVG Average per second Normal behavior None. Information only.
IMT Rx Packet Per Minute AVG Average per minute Normal behavior None. Information only.
IMT Rx Packet Per Second AVG Average per second Normal behavior None. Information only.
IMT Tx Packet Per Minute AVG Average per minute Normal behavior None. Information only.
IMT Tx Packet Per Second AVG Average per second Normal behavior None. Information only.
IMT Rx Errors Per Minute AVG Average per minute Normal behavior None. Information only.
IMT Rx Errors Per Second AVG Average per second Normal behavior None. Information only.
IMT Tx Errors Per Minute AVG Average per minute Normal behavior None. Information only.
IMT Tx Errors Per Second AVG Average per second Normal behavior None. Information only.
IMT Rx Safety Per Minute AVG Average per minute Normal behavior None. Information only.
IMT Rx Safety Per Second AVG Average per second Normal behavior None. Information only.
IMT Rx MSU Byte Per Minute AVG Average bytes per minute received on the line card interface within reliable delivery packets. Normal behavior None. Information only.
IMT Rx MSU Byte Per Second AVG Average bytes per second received on the line card interface within reliable delivery packets. Normal behavior None. Information only
IMT Rx ASU Byte Per Minute AVG Average bytes per minute received on the line card interface within acknowledgment packets. Normal behavior None. Information only.
IMT Rx ASU Byte Per Second AVG Average bytes per second received on the line card interface within acknowledgment packets. Normal behavior None. Information only
IMT Rx DSU Byte Per Minute AVG Average bytes per minute received on the line card interface within best effort delivery packets. Normal behavior None. Information only.
IMT Rx DSU Byte Per Second AVG Average bytes per second received on the line card interface within best effort delivery packets. Normal behavior None. Information only.
IMT Rx MSU Byte Count Number of bytes received on the line card interface within reliable delivery packets. Normal behavior None. Information Only
IMT Rx ASU Byte Count Number of bytes received on the line card interface within acknowledgment packets. Normal behavior None. Information only.
IMT Rx DSU Byte Count Number of bytes received on the line card interface within best effort delivery packets. Normal behavior None. Information only.
IMT RX HSU Byte Count Number of bytes received on the line card interface within mux specific packets. Normal behavior None. Information only.
IMT Rx LSSU Byte Count Number of bytes received on the line card interface within virtual circuit alignment packets. Normal behavior None. Information only.
IMT Rx TSU Byte Count Number of bytes received on the line card interface within test data packets. Normal behavior None. Information only
IMT Rx SSU Byte Count Number of bytes received on the line card interface within safety packets. Normal behavior. None. Information only.
IMT Rx BSU Byte Count Number of bytes received on the line card interface within broadcast packets. Normal behavior None. Information only.
IMT Rx Byte Other Number of bytes received on the line card interface within data packets other than the above. Normal behavior None. Information only.
IMT Rx Total Byte Count Number of bytes received on the line card interface within all types of packets. Normal behavior None. Information only.
IMT Rx MSU Packet Count Number of reliable delivery packets received on the IMT. Normal behavior None. Information only.
IMT Rx ASU Packet Count Number of acknowledgment packets received on the IMT. Normal behavior None. Information only.
IMT Rx DSU Packet Count Number of best effort delivery message data packets received on the IMT. Normal behavior None. Information only.
IMT Rx HSU Packet Count Number of mux card data packets received on the IMT. Normal behavior None. Information only.
IMT Rx LSSU Packet Count Number of virtual circuit alignment packets received on the IMT. Normal behavior None. Information only.
IMT Rx TSU Packet Count Number of test data packets received on the IMT. Normal behavior. None. Information only.
IMT Rx SSU Packet Count Number of safety packets received on the IMT. Normal behavior None. Information only.
IMT Rx BSU Packet Count Number of broadcast data packets received on the IMT. Normal behavior None. Information only.
IMT Rx Packet Other Number of all packets types not counted by one of the above. Normal behavior None. Information only.
IMT Rx Total Packet Count Number of packets received on the IMT, all types. Normal behavior None. Information only.
IMT Rx MSU Packet Safety Count Number of reliable delivery message data packets that did not arrive to the intended recipient on the IMT. Normal behavior None. Information only.
IMT Rx ASU Packet Safety Count Number of acknowledgment packets that did not arrive to the intended recipient on the IMT. Normal behavior None. Information only.
IMT Rx DSU Packet Safety Count Number of best effort delivery packets that did not arrive to the intended recipient on the IMT. Normal behavior None. Information only.
IMT Rx HSU Packet Safety Count Number of mux card packets that did not arrive to the intended recipient on the IMT. Normal behavior None. Information only.
IMT Rx LSSU Packet Safety Count Number of virtual circuit alignment packets that did not arrive to the intended recipient on the IMT. Normal behavior None. Information only.
IMT Rx TSU Packet Safety Count Number of test data packets that did not arrive to the intended recipient on the IMT. Normal behavior None. Information only.
IMT Rx SSU Packet Safety Count Number of safety packets that did not arrive to the intended recipient on the IMT. Normal behavior None. Information only.
IMT Rx BSU Packet Safety Count Number of broadcast data packets that did not arrive to the intended recipient on the IMT. Normal behavior None. Information only.
IMT Rx Other Packet Safety Count Number of other packets types not included above that did not arrive to the intended recipient on the IMT. Normal behavior None. Information only.
IMT Rx Total Packet Safety Count Number of all packets that did not arrive to the intended recipient on the IMT. Normal behavior None. Information only.
IMT Rx Packet Violation Error Number of packets received that contained an illegal character. Card insertion, removal, boot or defective hardware Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If errors continue, a hardware issue exists. Contact Customer Care Center.
IMT Rx Packet CRC Error Receive CRC error: Bad Checksum in received IMT packet. Caused by corrupted data within the received packet. Detected by hardware. Card insertion, removal, or boot.  Does not occur in a normal system and indicates a hardware failure: defective LIM card, MUX card, FC cable or backplane. Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If errors continue, a hardware issue exists. Contact Customer Care Center.
IMT Rx Packet Format Error Receive Format error: Occurs when the End of Message byte of an IMT packet is found missing. Detected by hardware/software. Card insertion, removal, or boot.  Does not occur in a normal system and indicates a hardware failure: defective LIM card, MUX card, FC cable or backplane. Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If errors continue, a hardware issue exists. Contact Customer Care Center.
IMT Rx Packet Discard Error Number of packets received that were discarded by this interface. Relatively heavy traffic on this interface can cause these counts to increment. Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear then there is no action to perform. If errors continue, a problem may exist. Contact Customer Care Center.
IMT Tx Packet Format Error Number of packets transmitted that were detected to contain a data format error. Maintenance activity: Card insertion, removal, or boot. Does not occur in a normal system and indicates a hardware failure: defective LIM card, MUX card, FC cable or backplane. Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear then there is no action to perform. If errors continue, a problem may exist. Contact Customer Care Center.
IMT Tx Packet Discard Error Number of packets that were discarded by the transmit interface. Relatively heavy traffic on this interface can cause these counts to increment. Clear IMT stats, wait 1 hour and retrieve stats again. if stats are clear then there is no action to perform. If errors continue a problem may exist. Contact Customer Care Center.
Miscellaneous Summary
Table 4-45 rept-imt-info Statistics, Miscellaneous Summary
Shelf ID UART Framing Error The Mux card at this location detected a framing error within the data stream containing its shelf address, transmitted by the MASP through the clock cable. These errors can occur when a Mux card or a MASP has booted or been inserted/ removed from the slot. Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If the errors continue, a problem may exist. Contact the Customer Care Center.
Shelf ID UART Overrun Error The Mux card at this location detected a overrun error in the data stream containing its shelf address, transmitted by the MASP through the clock cable. These errors can occur when a Mux card or a MASP has booted or been inserted/ removed from the slot. Clear IMT stats, wait 1 hour and retrieve stats again. If stats are clear, there is no action to perform. If the errors continue, a problem may exist. Contact the Customer Care Center.
Output
An asterisk (*) is appended to each statistic in the output when one or more MUX cards are unable to report statistics during the collection of IMT statistics.
IMT statistics are displayed as '-' instead of zero for counts when the IMT bus is down or inhibited in the output for rept-imt-info reports for MUX cards.
rlghncxa03w 04-02-27 12:47:07 EST  EAGLE 31.3.0
    IMT Fault Isolation Error Statistics
    SUMMARY REPORT: Totals accumulated from all requested cards for all buckets
    Statistic                 Bus A Value    Bus B Value
    Rcv CRC Err                       12              1
    Primary Ctl Rcv Err               23              3
    Violation Err                     34              5
    CPU Rcv FIFO Full                 45             12
    Totals accumulated from all requested cards for each bucket
    Bucket      Statistic                 Bus A Value    Bus B Value
    00          Rcv CRC Err                        1              2
                Rcv Invalid Len           1012345678              0
                CPU Rcv FIFO Full                 23            123
    01          No errors in this bucket.
.        (data continues for each hourly time period)
    00          Rcv CRC Err                        0              0
                Rcv Format Err                     0              0
                Rcv Invalid Len                    1              0
                Primary Ctl Rcv Err                0              0
                Primary Ctl Tx Err                 0              0
                Primary Ctl Sanity Err             0              0
                Violation Err                      1              0
                IMT Rcv FIFO Half Full             0              0
                IMT Rcv FIFO Full                  0              0
                CPU Rcv FIFO Half Full             0              0
                CPU Rcv FIFO Full                  0              0
                MSU Retransmitted                  0              0
                DMA Terminal Ct Intrpt             0              0
                SSU Pkts Txd                       0              0
                SSU Pkts Rcvd                      0              0
    01          Rcv CRC Err                        3              0
                Rcv Format Err                     0              0
                Rcv Invalid Len                    0              0
                Violation Err                      0              0
                SSU Pkts Txd                       0              0
                SSU Pkts Rcvd                      0              0
    Rcv CRC Err                        3              0
    Rcv Format Err                     0              0
    Rcv Invalid Len                    1              0
    Primary Ctl Rcv Err       1012345678              0
    Violation Err                      1              0
    CPU Rcv FIFO Half Full            23              0
    SSU Pkts Txd                       1              0
    SSU Pkts Rcvd                      0              0
This example output displays the output when IMT Bus A and Bus B are normal and all HMUX cards are reporting the statistics:
rept-imt-info:report=hmuxerr:sbucket=0
rlghncxa03w 10-01-17 00:10:20 PST  EAGLE 42.0.0
    HMUX Summary Report: Summed across all requested cards for each bucket
    Collecting HMUX stats: Extended processing time required.
    HMUX Hourly Bucket Statistics
    Bucket Low Speed Statistic           BUS A Value  BUS B Value
    00     IMT Rx Packet CRC Error       0123456789   0123456789
           IMT Rx Packet Format Error    0123456789   0123456789
           IMT Rx Violation Error        0123456789   0123456789
           CPU Rx FIFO Full              0123456789   0123456789
           CPU Rx FIFO Half Full         0123456789   0123456789
           CPU Rx FIFO Empty Before SOM  0123456789   0123456789
           CPU Rx FIFO Empty Before EOM  0123456789   0123456789
           CPU Rx Packet SOM Before EOM  0123456789   0123456789
           CPU Rx Packet CRC Error       0123456789   0123456789
           DMA terminal count            0123456789   0123456789
           CPU Tx Buffer EOB             0123456789   0123456789
           CPU Tx Buffer Full            0123456789   0123456789
           CPU Tx Buffer Half Full       0123456789   0123456789
           IMT Bypass FIFO Full          0123456789   0123456789
           IMT Bypass FIFO Half Full     0123456789   0123456789
           IMT Rx FIFO Full              0123456789   0123456789
           IMT Rx FIFO Half Full         0123456789   0123456789
           High Speed Statistic          BUS A Value  BUS B Value
           IMT Rx Disparity Error        0123456789   0123456789
           IMT Rx Sync Lost Error        0123456789   0123456789
           IMT Rx Code Word Error        0123456789   0123456789
           Misc Speed Statistic          BUS A Value  BUS B Value
           Shelf ID UART Framing Error   0123456789   0123456789
           Shelf ID UART Overrun Error   0123456789   0123456789
    HMUX CUMULATIVE Statistics
This example shows the output when IMT Bus A and Bus B are normal and all MUX cards are reporting the statistics:
    HIPR Summary Report: Summed across all requested cards for each bucket
    HIPR Hourly Bucket Statistics
    Bucket Loc   Low Speed Statistic           BUS A Value  BUS B Value
    00     ----  IMT Rx Packet CRC Error       0123456789   0123456789
                 IMT Rx Command Error          0123456789   0123456789
                 IMT Tx FIFO Full              0123456789   0123456789
                 IMT Tx FIFO Half Full         0123456789   0123456789
                 IMT Rx Packet SOM Before EOM  0123456789   0123456789
                 IXP Rx FIFO Full              0123456789   0123456789
                 IXP Rx FIFO Half Full         0123456789   0123456789
    HIPR CUMULATIVE Statistics
This example shows the output when both IMT Bus A and Bus B are normal and all MUX cards are reporting the statistics:
    00     1101  IMT Rx Packet CRC Error       0123456789   0123456789
    00     1102  IMT Rx Packet CRC Error       0123456789   0123456789
rept-imt-info:report=hipr2err:sbucket=0
tekelecstp 11-16-12 14:01:34 EST  EAGLE 44.0.0
    HIPR2 Summary Report: Summed across all requested cards for each bucket
    HIPR2 Hourly Bucket Statistics
                 IMT Rx Byte Per Minute AVG             0123456789   0123456789
                 IMT Rx Byte Per Second AVG             0123456789   0123456789
                 IMT Tx Byte Per Minute AVG             0123456789   0123456789
                 IMT Tx Byte Per Second AVG             0123456789   0123456789
                 IMT Rx Packet Per Minute AVG           0123456789   0123456789
                 IMT Rx Packet Per Second AVG           0123456789   0123456789
                 IMT Tx Packet Per Minute AVG           0123456789   0123456789
                 IMT Tx Packet Per Second AVG           0123456789   0123456789
                 IMT Rx Errors Per Minute AVG           0123456789   0123456789
                 IMT Rx Errors Per Second AVG           0123456789   0123456789
                 IMT Tx Errors Per Minute AVG           0123456789   0123456789
                 IMT Tx Errors Per Second AVG           0123456789   0123456789
                 IMT Rx Safety Per Minute AVG           0123456789   0123456789
                 IMT Rx Safety Per Second AVG           0123456789   0123456789
                 IMT Rx MSU Byte Per Minute AVG         0123456789   0123456789
                 IMT Rx MSU Byte Per Second AVG         0123456789   0123456789
                 IMT Rx ASU Byte Per Minute AVG         0123456789   0123456789
                 IMT Rx ASU Byte Per Second AVG         0123456789   0123456789
                 IMT Rx DSU Byte Per Minute AVG         0123456789   0123456789
                 IMT Rx DSU Byte Per Second AVG         0123456789   0123456789
                 IMT Rx MSU Byte Count                  0123456789   0123456789
                 IMT Rx ASU Byte Count                  0123456789   0123456789
                 IMT Rx DSU Byte Count                  0123456789   0123456789
                 IMT Rx HSU Byte Count                  0123456789   0123456789
                 IMT Rx LSSU Byte Count                 0123456789   0123456789
                 IMT Rx TSU Byte Count                  0123456789   0123456789
                 IMT Rx SSU Byte Count                  0123456789   0123456789
                 IMT Rx BSU Byte Count                  0123456789   0123456789
                 IMT Rx Byte Other                      0123456789   0123456789
                 IMT Rx Total Byte Count                0123456789   0123456789
                 IMT Rx MSU Packet Count                0123456789   0123456789
                 IMT Rx ASU Packet Count                0123456789   0123456789
                 IMT Rx DSU Packet Count                0123456789   0123456789
                 IMT Rx HSU Packet Count                0123456789   0123456789
                 IMT Rx LSSU Packet Count               0123456789   0123456789
                 IMT Rx TSU Packet Count                0123456789   0123456789
                 IMT Rx SSU Packet Count                0123456789   0123456789
                 IMT Rx BSU Packet Count                0123456789   0123456789
                 IMT Rx Packet Other                    0123456789   0123456789
                 IMT Rx Total Packet Count              0123456789   0123456789
                 IMT Rx MSU Packet Safety Count         0123456789   0123456789
                 IMT Rx ASU Packet Safety Count         0123456789   0123456789
                 IMT Rx DSU Packet Safety Count         0123456789   0123456789
                 IMT Rx HSU Packet Safety Count         0123456789   0123456789
                 IMT Rx LSSU Packet Safety Count        0123456789   0123456789
                 IMT Rx TSU Packet Safety Count         0123456789   0123456789
                 IMT Rx SSU Packet Safety Count         0123456789   0123456789
                 IMT Rx BSU Packet Safety Count         0123456789   0123456789
                 IMT Rx Other Packet Safety Count       0123456789   0123456789
                 IMT Rx Total Packet Safety Count       0123456789   0123456789
                 IMT Rx Packet Violation Error          0123456789   0123456789
                 IMT Rx Packet Discard Error            0123456789   0123456789
                 IMT Tx Packet Format Error             0123456789   0123456789
                 IMT Tx Packet Discard Error            0123456789   0123456789
    HIPR2 CUMULATIVE Statistics
This example shows the output when IMT Bus A is inhibited:
rlghncxa03w 10-01-27 00:10:20 PST  EAGLE 42.0.0
    00     ----  IMT Rx Packet CRC Error               -             0
                 IMT Rx Packet Format Error            -             0
                 IMT Rx Violation Error                -           101
                 IMT Rx Command Error                  -             0
                 IMT Rx FIFO Full                      -             0
                 IMT Rx FIFO Half Full                 -             0
                 IMT Tx FIFO Full                      -             0
                 IMT Tx FIFO Half Full                 -             0
                 IMT Rx Disparity Error                -             0
                 IMT Rx Sync Lost Error                -             0
                 IMT Rx Code Word Error                -             0
                 IMT Rx Packet SOM Before EOM          -             0
                 IMT Bypass FIFO Full                  -             0
                 IMT Bypass FIFO Half Full             -             0
                 IXP Rx FIFO Full                      -             0
                 IXP Rx FIFO Half Full                 -             0
                 Shelf ID UART Framing Error           -             0
                 Shelf ID UART Overrun Error           -             0
                 IMT Rx Violation Error                -          1165
                 IMT Tx FIFO Half Full                 -             1
                 IMT Bypass FIFO Full                  -             1
                 IMT Bypass FIFO Half Full             -             1
                 Shelf ID UART Framing Error           -            35
This example shows the output when at least one card on the IMT Bus does not respond when statistics are collected:
    00     ----  IMT Rx Packet CRC Error               0            0
                 IMT Rx Packet Format Error            0            0
                 IMT Rx Violation Error              128            0
                 IMT Rx Command Error                  0            0
                 IMT Rx FIFO Full                      0            0
                 IMT Rx FIFO Half Full                 0            0
                 IMT Tx FIFO Full                     36            0
                 IMT Tx FIFO Half Full               182            0
                 IMT Rx Disparity Error                0            0
                 IMT Rx Sync Lost Error                0            0
                 IMT Rx Code Word Error                0            0
                 IMT Rx Packet SOM Before EOM          0            0
                 IMT Bypass FIFO Full                  0            0
                 IMT Bypass FIFO Half Full             0            0
                 IMT Tx FIFO Full                      0            0
                 IMT Tx FIFO Half Full                 0            0
                 IXP Rx FIFO Full                      0            0
                 IXP Rx FIFO Half Full                 0            0
                 Shelf ID UART Framing Error           2            0
                 Shelf ID UART Overrun Error           0            0
                 IMT Rx Packet CRC Error               0           0*
                 IMT Rx Packet Format Error            0           0*
                 IMT Rx Violation Error             1415           0*
                 IMT Rx Command Error                  0           0*
                 IMT Rx FIFO Full                      0           0*
                 IMT Rx FIFO Half Full                 0           0*
                 IMT Tx FIFO Full                    120           0*
                 IMT Tx FIFO Half Full              1113           0*
                 IMT Rx Disparity Error                0           0*
                 IMT Rx Sync Lost Error               15           0*
                 IMT Rx Code Word Error                0           0*
                 IMT Rx Packet SOM Before EOM          0           0*
                 IMT Bypass FIFO Full                  1           0*
                 IMT Bypass FIFO Half Full             1           0*
                 IMT Tx FIFO Full                      0           0*
                 IMT Tx FIFO Half Full                 0           0*
                 IXP Rx FIFO Full                      0           0*
                 IXP Rx FIFO Half Full                 0           0*
                 Shelf ID UART Framing Error          59           0*
                 Shelf ID UART Overrun Error           0           0*
Legend
IMT Statistics:
  • Bucket—The hourly time periods (buckets) for which a report was requested.
  • Statistic—The error statistic type for the IMT buses A and B.
  • Bus A Value—The number of occurrences of the type of error displayed in the Statistic column for the IMT bus A.
  • Bus B Value—The number of occurrences of the type of error displayed in the Statistic column for the IMT bus B.
  • Low Speed Statistic—The error statistic type for the low speed 125 Mbps secondary rings with MUX cards installed on buses A (xy09 card locations) and B (xy10 card locations).
  • High Speed Statistic—The error statistic type for the high-speed 1 Gbps primary ring with MUX cards installed on buses A (xy09 card locations) and B (xy10 card locations).
  • Misc Speed Statistics—Shelf ID Universal Asynchronous Receiver Transmitter (UART) error counts on the MUX cards installed on buses A (xy09 card locations) and B (xy10 card locations).
  • Bucket Summary—The error count for each parameter for one hour for HMUX cards installed on buses A (xy09 card locations) and B (xy10 card locations). (The count is for the most recent part of an hour if the card was booted within an hour of executing the rept-imt-info command.)
  • Cumulative—The running total error count for each parameter since card initialization for HMUX cards installed on buses A (xy09 card locations) and B (xy10 card locations).
MUX Statistics:
  • Loc—The card location (shelf and slot) for which information is displayed.
  • Misc Speed Statistic—The miscellaneous error statistic type.
  • Bus A—The number of occurrences of the type of error displayed in the Statistic column for the IMT bus A.
  • Bus B—The number of occurrences of the type of error displayed in the Statistic column for the IMT bus B.
