4.396 rept-stat-card
Use this command to display the card status and maintenance activity states. The output includes card location, the GPL version being used by the card, device type, device primary state, device secondary state, and device associated state.
Parameters
appl (optional)
Application. The status of cards running the specified application.
Range:
xyyyyyy
1 alphabetic character followed by up to 6 alphanumeric characters. Valid applications are:
atmansi —Used by E5-ATM-B cards to support ATM high-speed signaling links and T1 functions.
atmitu —Used by E5-ATM-B cards to support E1 high-speed signaling links and E1 functions.
ccs7itu —Used by E5-E1T1-B cards for ITU MTP functions.
deirhc —Used by E5-SM8G-B and SLIC cards to support the DEIR application.
elap —Used by E5-APP-B cards to support the ELAP application.
enumhc —Used by E5-SM8G-B cards to support the ENUM Mobile Number Portability and Tier One Address Resolution application.
epap —Used by E5-APP-B cards to support the EPAP application.
eroute —Used by STC cards and E5-STC cards for the EAGLE 5 Integrated Monitoring Support functions
gls —Used by E5-TSM cards for downloading gateway screening to LIM and Service Module cards
ipgwi —Used by E5-ENET-B cards for point-to-multipoint IP connectivity for ITU point codes. A maximum of 125 cards can be assigned the IPGWI application.
iplimi —Used by E5-ENET-B cards for point-to-point IP connectivity for ITU point codes
ips —Used by E5-IPSM and E5-ENET-B cards for the IP User Interface feature.
ipsg —Used by E5-ENET-B, and SLIC cards to support the combined functionality of IPLIMx M2PA and IPGWx M3UA
lsms - Used by E5-APP-B cards to support LSMS application.
mcp —Used by E5-MCPM-B cards for the Measurements Platform feature.
nas - Used by E5-APP-B cards to support the NAS application.
siphc — Used by E5-SM8G-B cards to support the SIP application.
ss7ansi —Used by E5-E1T1-B cards for ANSI MTP functions
ss7ipgw —Used by E5-ENET-B cards for point-to-multipoint IP connectivity. The system allows a maximum of 125 cards to be assigned the SS7IPGW application.
switch - Used by Telco switch to add power consumed by Telco Switch to Frame Power Budget. This is not an application gpl.
vsccp —Used by Service Module cards to support EPAP-based features and the LNP ELAP Configuration features. If no EPAP-based or LNP ELAP Configuration feature is turned on, and a Service Module card is present, then normal GTT traffic is processed.
data (optional)
Data filter specification. The status of cards running the specified application with specified data.
Range:
nosccp
displays the status of a GTT-disabled IPSG card
gtt
displays the status of a GTT-enabled IPSG card and SM GTT card
The data parameter is valid for IPSG and VSCCP applications only. If the data parameter is not specified, then both types of IPSG (GTT disabled and GTT enabled) cards will be displayed under appl=ipsg.
links (optional)
Filter specification. Report the maximum number of links, only equipped links, or only unequipped links on the card in the specified card location (loc).
Range:
all
Reports the maximum number of links available on the card in the specified loc
equip
Reports only links that are equipped
unequip
Reports only links that are unequipped
Default:
equip
loc (optional)
Card address. The card location as stenciled on the shelf of the system.
Range:
1101 - 1117, 1201 - 1218, 1301 - 1318, 2101 - 2118, 2201 - 2218, 2301 - 2318, 3101 - 3118, 3201 - 3218, 3301 - 3318, 4101 - 4118, 4201 - 4218, 4301 - 4318, 5101 - 5118, 5201 - 5218, 5301 - 5318, 6101 - 6118, 6201 - 6218, 6301 - 6318
Default:
A status of all cards is displayed.
mode (optional)
Mode. The type of report to display (full or summary).
Range:
full
Default:
A summary report is displayed.
stat (optional)
Primary state filter. This parameter cannot be used with the loc or mode parameters. This filter allows printing of cards in a specified state (all in-service cards, for example).
Range:
all
All of the primary states
alminh
Alarms inhibited
anr
In service abnormal (IS-ANR)
dsbld
Out of service maintenance disabled (OOS-MT-DSBLD)
mt
Out of service maintenance (OOS-MT)
nr
In service normal (IS-NR)
Default:
all
Example
rept-stat-card
rept-stat-card:loc=1201
rept-stat-card:loc=1201:mode=full
rept-stat-card:stat=alminh
rept-stat-card:appl=ss7ansi
rept-stat-card:appl=siphc
rept-stat-card:loc=1205:links=equip:mode=full
rept-stat-card:appl=epap
rept-stat-card:appl=switch
rept-stat-card:appl=elap
rept-stat-card:appl=lsms
rept-stat-card:appl=nas
rept-stat-card:appl=enumhc
rept-stat-card:appl=ipsg:data=gtt
rept-stat-card:appl=ipsg:data=nosccp
Dependencies
No other command can be in progress when this command is entered.
The mode parameter can be specified only when the loc parameter is specified.
Only one of the loc or stat parameters can be specified in the command.
Unless the appl=vcssp/ipsg, no other parameter can be specified with the appl parameter.
The shelf and card must be equipped.
The card location (loc) must be within the allowed range.
A valid value must be specified for the appl parameter.
The card location specified by the loc parameter must be equipped.
The data parameter is not valid with an APPL other than IPSG/VSCCP.
The data parameter can take nosccp as a value only when the APPL specified is IPSG.
Notes
LIM cards show MFC results for SNM, SCCP, EROUTE, INM and MTP3. SCCP cards show MFC results for SNM, INM and MTP3 when the mode=full and loc parameters are specified.
The status displayed is for the previous 5 minutes and the previous 24 hours.
The following MFC status codes are used: G to indicate service request GRANTED, D to indicate service request DENIED, and N to indicate NO OPERATIONAL SERVERS AVAILABLE.
This command can be canceled using the F9 function key or the canc-cmd command. See canc-cmd for more information.
The mode=full parameter gives more information than the summary report.
A plus (+) symbol in the output indicates that the flash GPL currently being run has not yet been activated on the card. See the act/init-flash command for a list of flash GPLs.
E1 alarms are displayed in the alarm status field. When the mode=full parameter is specified, separate fields display status information from the UAM for each E1 interface on the card. For each E1 interface, the display shows the highest priority E1 failure that exists on that E1 card. When no E1 errors exist, the clearing E1 UAM text is displayed. When an E1 interface is not assigned to the card, no output is generated for that E1 position.
T1 alarms are displayed in the alarm status field. When the mode=full parameter is specified, separate fields display status information from the UAM for each T1 interface on the card. For each T1 interface, the display shows the highest priority T1 failure that exists on that T1 card. When no T1 errors exist, the clearing T1 UAM text is displayed. When an T1 interface is not assigned to the card, no output is generated for that T1 position.
If the links=all parameter is specified, then the maximum number of supported SS7 links on the card is displayed as shown. If the links=unequip parameter is specified, then the number of links displayed is equal to the maximum supported links minus the provisioned links. If the links=equip parameter is specified, then only the provisioned links are displayed.
Multiple cards of the same card type but different capacity can be installed into a slot configured with the ent-card command. The number of links supported cannot be determined until the card is physically installed into the configured slot.
Table 4-50 Maximum Supported Links based on Card Type and GPL
GPL with Card Type Maximum Supported Links
Card Hardware Verified Card Hardware Unknown
ATMHC on E5-ATM-B 3 3
SS7HC on E5-E1T1-B 64 64
IPLHC on E5-ENET-B 16 16
IPGHC on E5-ENET-B 1 1
IPSG on E5-ENET-B/SLIC 32 32
IPSG on SLIC 128 128
SIPHC on E5-SM8G-B/SLIC 17 (16 TCP & 1 UDP) 17 (16 TCP & 1 UDP)
ENUMHC on E5-SM8G-B/SLIC 1 (UDP) 1 (UDP)
DEIRHC on E5-SM8G-B/SLIC 32 32
The CARD WARNING field in the command output indicates a specific condition that can hinder the normal functioning of a card. For E5-E1T1-B cards, the "Obsolete Framer" warning indicates that a port configured on the card may get stuck in a Loss of Frame (LOF) state. If an E5-E1T1-B card displaying this warning is reloaded, and one of the ports on the card is reporting LOF, then the OAM reboots the card up to 5 times to attempt to clear the LOF condition when the card changes state from IS-ANR to IS-NR.
GTT-enabled IPSG cards have the IPSG application running on SLIC hardware, which is capable of SCCP (GTT) processing. GTT-disabled IPSG cards also have IPSG application running on E5-ENET-B or SLIC hardware, but they do not have SCCP (GTT) processing capability. To sort one from the other, the data parameter is used. The data parameter cannot be used with any application other than IPSG/VSCCP.
Interface A/D will be used for ExAP connectivity running SIP/ENUM application and interface B/C used for signaling network on the SLIC card running the DEIR/SIP/ENUM application.
Fast Copy Cards
E5-ENET-B, or SLIC cards running the IPSG or E5-ENET-B cards running the IPGHC GPL are considered to be FC- capable. A card running the IPGHC GPL must be in the IS-NR State before the card can be considered FC- capable. This restriction does not apply to cards running the IPSG GPL. An FC- capable card is considered FC- enabled when Fast Copy monitoring is enabled for the respective GPL.
Output
The clock status fields are reported when the mode=full report is selected. The clock status report includes a CLOCK A, CLOCK B, and CLOCK I status. The High Speed clock status report (displayed for ATM, E1 and T1 cards) includes HS CLOCK A, HS CLOCK B, and HS CLOCK I. The valid values for each clock status are Idle, Active, and Fault. The meanings of these values are:
  • Idle —Clock is available but is not being used by the card
  • Active —Clock is available and is being used by the card
  • Fault —Clock is unavailable
Idle and Active are shown when the CLK or HS CLK distribution to the card is good. The Active value does not denote that the card is actually using the clock source for link alignment. Use the rtrv-slk, rtrv-e1, and rtrv-t1 commands to determine what clock source each card is using for link alignment.
If the mode=full parameter is specified for an FC-enabled card, and Fast Copy functionality has been provisioned for the GPL (see the chg-eisopts command), then Fast Copy status and FC Link status is shown. For an E5-ENET-B or SLIC card running the IPGHC GPL, Fast Copy and Fast Copy link status is shown only when the card is in IS-NR state.
Abbreviated output is indicated by 3 vertical dots as shown:
The E5-MCPM-B card is an MCPM card. The Type field displays MCPM.
rept-stat-card
    rlghncxa03w 12-03-09 16:35:57 IST  EAGLE 45.0.0
    CARD   VERSION      TYPE      GPL        PST            SST       AST
    1102   128-002-000  LIMATM    ATMHC      IS-NR          Active    -----
    1103   125-020-000  DSM       SCCPHC     IS-NR          Active    -----
    1105   125-020-000  DSM       SCCPHC     IS-NR          Active    -----
    1106   130-001-000  TSM       GLSHC      IS-NR          Active    -----
    1107   125-020-000  STC       EROUTE     IS-NR          Active    -----
    1108   134-000-000  MCPM      MCPHC      IS-NR          Active    -----
    1109   125-020-000  HIPR2     HIPR2      IS-NR          Active    -----
    1110   125-020-000  HIPR2     HIPR2      IS-NR          Active    -----
    1111   125-020-000  IPSM      IPS        IS-NR          Active    -----
    1113   070-019-002  E5MCAP    OAMHC      IS-NR          Standby   -----
    1114   -----------  E5TDM                IS-NR          Active    -----
    1115   070-019-002  E5MCAP    OAMHC      IS-NR          Active    -----
    1116   -----------  E5TDM                IS-NR          Active    -----
    1117   -----------  MDAL                 IS-NR          Active    -----
    1201   138-008-000  SLIC      IPSG       IS-NR          Active    -----
    1206   134-060-000  DSM       DEIRHC     IS-NR          Active    -----
    1209   125-020-000  HIPR2     HIPR2      IS-NR          Active    -----
    1210   125-020-000  HIPR2     HIPR2      IS-NR          Active    -----
    1112   138-008-000  SLIC      IPSG       IS-NR          Active    -----
    1309   125-017-000  HIPR2     HIPR2      IS-NR          Active    -----
    1310   125-017-000  HIPR2     HIPR2      IS-NR          Active    -----
    1311   125-020-000  STC       EROUTE     IS-NR          Active    -----
    2103   128-018-000  DCM       IPLHC      IS-NR          Active    -----
    2109   128-022-000  HIPR2     HIPR2      IS-NR          Active    -----
    2110   128-022-000  HIPR2     HIPR2      IS-NR          Active    -----
    2111   128-018-000  STC       ERTHC      IS-NR          Active    -----
    1213   053-000-058  E5ENET    IPSG       IS-NR          Active    -----
    Command Completed.
This example shows the card status for the OAMHC of MASP A located in slot 1113, which is currently active.
This example also shows a Hardware Verification Code. The HW VERIFICATION CODE field is shown only in the mode=full report. "-----" is shown for cards with valid hardware. A numerical value is shown when invalid hardware is detected. All such cards will be auto-inhibited. The numerical values are listed in Table 4-51. The E5-MDAL and MUX cards do not display the field in mode=full reports on their locations.
rept-stat-card:loc=1113:mode=full
tekelecstp 02-01-08 04:34:09 EST  EAGLE 46.0.0
    1113   134-068-000  E5MCAP    OAMHC      IS-NR          Active     -----
      ALARM STATUS       =  No Alarms
      BLMCAP  GPL version = 134-054-000
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CLOCK A             = Fault
      CLOCK B             = Active
      CLOCK I             = Idle
      MBD BIP STATUS      = Valid
      MOTHER BOARD ID     = E5-MCAP
      DBD STATUS          = Valid
      DBD TYPE            = 1G ENET
      DBD MEMORY SIZE     = 4096M
      HW VERIFICATION CODE = ----
      CURRENT TEMPERATURE   =  32C ( 90F)
      PEAK TEMPERATURE:     =  32C ( 90F)     [02-01-08 04:31]
      TROUBLE TEXT VER.  = Rev 134.10.2
      APPLICATION SERVICING
                                        TVG    MFC         TVG    MFC
      IPLNK STATUS
          IPLNK  IPADDR             STATUS     PST
          A      ---------------    ----       ----
    Command Completed.
This example shows all cards that have alarms inhibited in the system:
    rlghncxa03w 04-02-04 12:57:21 EST  EAGLE 31.6.0
    CARD  VERSION      TYPE    APPL      PST           SST       AST
    1211  023-001-000  LIMATM ATMANSI   IS-NR         Active  ALMINH
    Command Completed.
This example shows a full report for a specified HIPR2 card:
rept-stat-card:loc=1109:mode=full
    tekelecstp 02-01-08 04:45:17 EST  EAGLE 46.0.0
    1109   134-046-000  HIPR2     HIPR2      IS-NR          Active     -----
      ALARM STATUS       = No Alarms.
      TRIAL VERSION      = HIPR2 134-069-000
      FPGA VERSION       = HIPR2 008-002-005-009
      CURRENT TEMPERATURE   = NA
      PEAK TEMPERATURE:     = NA
    Command Completed.
This example shows output for an STC card used by the E5IS feature:
rept-stat-card:loc=1107
    rlghncxa03w 10-01-09 16:35:57 IST  EAGLE 42.0.0
    1107   128-015-000  STC       EROUTE    IS-NR          Active     -----
      BPDCM   GPL version = 128-108-000
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CLOCK A             = Active
      CLOCK B             = Idle
      CLOCK I             = Idle
      MOTHER BOARD ID     = Invalid
      DBD STATUS          = Valid
      DBD TYPE            = Invalid
      DBD MEMORY SIZE     = 512M
      EROUTE % OCCUP     = 0%
      NTP broadcast = VALID
    Command Completed.
This example shows a full report for an STC card:
rept-stat-card:loc=1107:mode=full
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CLOCK A             = Active
      CLOCK B             = Idle
      CLOCK I             = Idle
      DBD STATUS          = Valid
      DBD TYPE            = Invalid
      EROUTE % OCCUP     = 0%
      IPLNK STATUS
          A      ---------------    DOWN       OOS-MT
          B      192.168.63.45      UP         IS-NR
      STC IP CONNECTION
          PORT   PST             SST
          A      OOS-MT          Unavail
          B      IS-NR           Active
This example shows output for an MCPM card used by the Measurements Platform feature:
rept-stat-card:loc=1105
    rlghncxa03w  11-05-04 15:10:19 EST  EAGLE 44.0.0
    1105   128-001-000  MCPM    MCP        IS-NR          Idle      -----
      BPDCM   GPL VERSION = 128-001-000
      IMT BUS A          = Conn
      IMT BUS B          = Conn
    Command Completed.
This example shows output for an E5-SM4G card:
rept-stat-card:loc=6111
    tklc1110501 10-12-09 17:26:29 EST  EAGLE5 43.0.0
    6111   128-015-000  DSM       SCCPHC     IS-NR          Active     -----
      BLIXP   GPL version = 133-044-000
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CURRENT TEMPERATURE   =  31C ( 88F)
      PEAK TEMPERATURE:     =  32C ( 90F)     [07-04-12 15:55]
      SCCP % OCCUP        = 1%
    Command Completed.
This example shows a full report for an E5-SM4G card. The MFC option is ON.
rept-stat-card:loc=6111:mode=full
rlghncxa03w 11-02-09 16:35:57 IST  EAGLE 44.0.0
    6111   134-000-000  DSM       SCCPHC     IS-NR          Active     -----
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CLOCK A             = Active
      CLOCK B             = Idle
      CLOCK I             = Idle
      MOTHER BOARD ID     = SMXG A
      DBD STATUS          = Valid
      DBD TYPE            = 1G ENET
      SCCP % OCCUP        = 1%
                                        TVG    MFC         TVG    MFC
          SNM     REQ STATUS =   24 hr: ------ ---, 5 min: ------ ---
          INM     REQ STATUS =   24 hr: ------ ---, 5 min: ------ ---
          MTP3    REQ STATUS =   24 hr:        ---, 5 min:        ---
      IPLNK STATUS
          A      10.220.9.9         UP         IS-NR
          B      10.220.9.8         UP         IS-NR
      DSM IP CONNECTION
          PORT   PST             SST
          A      OOS-MT          Unavail
          B      OOS-MT          Unavail
    Command Completed.
This example shows the output for all cards running the VSCCP application:
rept-stat-card:appl=vsccp
    tklc1110501 07-04-12 17:28:02 EST  EAGLE5 46.0.0
    1107   128-015-000  DSM       SCCPHC     IS-NR          Active     -----
    1317   -----------  DSM       SCCPHC     OOS-MT         Isolated   -----
    2217   128-015-000  DSM       SCCPHC     IS-NR          Active     -----
    2317   -----------  DSM       SCCPHC     OOS-MT         Isolated   -----
    3103   -----------  DSM       SCCPHC     OOS-MT-DSBLD   Manual     -----
    3201   128-015-000  DSM       SCCPHC     IS-NR          Active     -----
    3203   128-015-000  DSM       SCCPHC     IS-NR          Active     -----
    3205   128-015-000  DSM       SCCPHC     IS-NR          Active     -----
    3207   128-015-000  DSM       SCCPHC     IS-NR          Active     -----
    3211   128-015-000  DSM       SCCPHC     IS-NR          Active     -----
    3213   128-015-000  DSM       SCCPHC     IS-NR          Active     -----
    3215   128-015-000  DSM       SCCPHC     IS-NR          Active     -----
    3217   128-015-000  DSM       SCCPHC     IS-NR          Active     -----
    5317   128-015-000  DSM       SCCPHC     IS-NR          Active     -----
    6101   128-015-000  DSM       SCCPHC     IS-NR          Active     -----
    6103   128-015-000  DSM       SCCPHC     IS-NR          Active     -----
    6105   128-015-000  DSM       SCCPHC     IS-NR          Active     -----
    6107   128-015-000  DSM       SCCPHC     IS-NR          Active     -----
    6113   128-015-000  DSM       SCCPHC     IS-NR          Active     -----
    6115   128-015-000  DSM       SCCPHC     IS-NR          Active     -----
    6117   128-015-000  DSM       SCCPHC     IS-NR          Active     -----
    Command Completed.
This example shows a full report for a HIPR2 card:
rept-stat-card:loc=2109:mode=full
    rlghncxa03w  09-06-04 15:10:19 EST  EAGLE 5 41.1.0
      TRIAL VERSION      = HIPR2 023-099-008
      FPGA VERSION       = HIPR2 008-001-003-002
      CURRENT TEMPERATURE   =  73C (164F)
      PEAK TEMPERATURE:     =  73C (164F)     [02-01-05 10:12]
    Command Completed.
This example shows a full report for a card running the IPSG GPL. Fast Copy functionality has been provisioned for the IPSG GPL.
rept-stat-card:loc=1102:mode=full
    stpc9070501 11-05-04 17:43:56 EDT  EAGLE5 44.0.0
    1102   009-054-000  E5ENET    IPSG       IS-NR          Active     -----
      BLIXP   GPL version = 009-054-000
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CLOCK A             = Idle
      CLOCK B             = Active
      CLOCK I             = Idle
      MOTHER BOARD ID     = EPM A
      DBD STATUS          = Valid
      DBD TYPE            = 1G ENET
      CURRENT TEMPERATURE   =  42C (108F)
      PEAK TEMPERATURE:     =  43C (110F)     [11-05-04 13:55]
      SIGNALING LINK STATUS
          SLK    PST                LS            CLLI          E5IS
          A      IS-NR              stpa113n      stpa113n      INACTIVE
          B      IS-NR              sc2a115n      sc2a115n      INACTIVE
          A1     IS-NR              stpa113n      stpa113n      INACTIVE
          B1     IS-NR              sc2a115n      sc2a115n      INACTIVE
          A4     IS-NR              sp2a115n      sp2a115n      INACTIVE
          B4     IS-NR              sp3a116n      sp3a116n      INACTIVE
          A5     IS-NR              sp2a115n      sp2a115n      INACTIVE
          B5     IS-NR              sp3a116n      sp3a116n      INACTIVE
      IPLNK STATUS
          A      10.251.100.166     UP         IS-NR
          B      10.251.102.27      UP         IS-NR
      FCLNK STATUS
          A1     172.21.48.242      UP         IS-NR
          B1     172.22.48.242      UP         IS-NR
      FASTCOPY STATUS
          ONLINE
      ASSOCIATION STATUS
          ANAME              PST             SST
          ipn1102am2pa       IS-NR           ESTABLISHED
          ipn1102a1m2pa      IS-NR           ESTABLISHED
          gwn1102bm3ua       IS-NR           ESTABLISHED
          gwn1102b1m3ua      IS-NR           ESTABLISHED
          ipns1102a4m2pa     IS-NR           ESTABLISHED
          ipns1102a5m2pa     IS-NR           ESTABLISHED
          gwns1102b4m3ua     IS-NR           ESTABLISHED
          gwns1102b5m3ua     IS-NR           ESTABLISHED
                                        TVG    MFC         TVG    MFC
          SCCP    REQ STATUS =   24 hr: ------ ---, 5 min: ------ ---
          EROUTE  REQ STATUS =   24 hr: ------ G--, 5 min: ------ G--
          INM     REQ STATUS =   24 hr: ------ G--, 5 min: ------ ---
          MTP3    REQ STATUS =   24 hr:        G--, 5 min:        G--
    Command Completed.
This example shows a full report for a card running the IPSG application and receiving pure MTP routed traffic. The MFC option and E5IS feature are ON.
rept-stat-card:loc=1105:mode=full
e1080403 11-03-10 14:46:53 EST  EAGLE 44.0.0
    1105   134-000-000  E5ENETB   IPSG       IS-NR          Active     -----
      BLMCAP   GPL version = 056-042-000
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CLOCK A             = Active
      CLOCK B             = Idle
      CLOCK I             = Idle
      DBD STATUS          = Valid
      DBD TYPE            = 1G ENET
      CURRENT TEMPERATURE   =  43C (110F)
      PEAK TEMPERATURE:     =  45C (113F)     [11-03-08 10:18]
          B2     IS-NR              ipsg1105b2    -----------   INACTIVE
      IPLNK STATUS
          A      10.254.101.121     UP         IS-NR
          B      10.254.100.4       UP         IS-NR
      ASSOCIATION STATUS
          ANAME              PST             SST
          m3ua1105b2         IS-NR           ESTABLISHED
                                        TVG    MFC         TVG    MFC
          SNM     REQ STATUS =   24 hr: GDNHSI ---, 5 min: GD---- ---
          EROUTE  REQ STATUS =   24 hr: ------ GDN, 5 min: ------ G--
          INM     REQ STATUS =   24 hr: G----- ---, 5 min: G----- ---
    Command Completed.
This example shows a full report for an E5-TSM card:
rept-stat-card:loc=1106:mode=full
    tekelecstp 10-12-09 19:15:28 EST  EAGLE 43.0.0
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CLOCK A             = Active
      CLOCK B             = Idle
      CLOCK I             = Idle
      DBD STATUS          = Valid
      DBD TYPE            = None
      CURRENT TEMPERATURE   =  44C (112F)
      PEAK TEMPERATURE:     =  44C (112F)     [10-10-05 19:10]
    Command Completed.
This example shows the output when E5-MCAP, E5-TDM, and E5-MDAL cards are used:
rept-stat-card
    e5oam 14-12-01 15:38:32 EST  EAGLE 46.2.0
    1109   030-009-000  HIPR2     HIPR2      IS-NR          Active     -----
    1110   030-009-000  HIPR2     HIPR2      IS-NR          Active     -----
    1113   030-010-008  E5MCAP    OAMHC      IS-NR          Standby    -----
    1115   030-010-008  E5MCAP    OAMHC      IS-NR          Active     -----
    1117   -----------  E5MDAL               OOS-MT         Isolated   -----
    Command Completed.
This example shows the output for a HIPR2 card, which does not support thermal monitoring:
    Command Completed.
This example shows the output for a HIPR2 card when the card is not in-service:
    1209   -----------  HIPR2     HIPR2      OOS-MT         Isolated   -----
      FPGA VERSION       = HIPR2 ---------------
      CURRENT TEMPERATURE   = ----
      PEAK TEMPERATURE:     = ----
    Command Completed.
This example shows the output for an E5-OAM card when the Integrated Measurements feature is turned on:
    tekelecstp 02-01-08 04:50:35 EST  EAGLE 46.0.0
      IMT BUS A           = Conn
      IMT BUS B           = Conn
    Command Completed.
This example shows a full report for the E5-MASP of MASP A located in slot 1113, which is currently active:
tekelecstp 10-01-07 09:37:39 EST  EAGLE 42.0.0
    1113   030-002-022  E5MCAP    OAMHC      IS-NR          Active     -----
      BLMCAP  GPL version = 030-004-000
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CLOCK A             = Active
      CLOCK B             = Idle
      CLOCK I             = Idle
      DBD STATUS          = Valid
      DBD TYPE            = 1G ENET
      DBD MEMORY SIZE     = 2048M
      CURRENT TEMPERATURE   =   0C ( 32F)
      PEAK TEMPERATURE:     =   0C ( 32F)     [00-00-00 00:00]
      TROUBLE TEXT VER.  = Rev 133.1.2
      TVG STATUS
      IPLNK STATUS
          A      192.168.1.1        UP         IS-NR
This example shows a full report for an E5-MASP card when an IP mismatch condition exists:
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CLOCK A             = Active
      CLOCK B             = Idle
      CLOCK I             = Idle
      DBD STATUS          = Valid
      DBD TYPE            = 1G ENET
      TVG STATUS
      IPLNK STATUS
          IP Mismatch exists, reset required
This example shows a full report for an E5-ENET-B used as an STC card:
rlghncxa03w 11-03-09 16:35:57 EST  EAGLE 44.0.0
    1102   134-000-000  STC       ERTHC      IS-NR          Active     -----
      BLMCAP  GPL version = 032-000-000
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CLOCK A             = Fault
      CLOCK B             = Fault
      CLOCK I             = Idle
      MOTHER BOARD ID     = EPM B
      DBD STATUS          = Valid
      DBD TYPE            = 1G ENET
      CURRENT TEMPERATURE   =  62C (144F)
      PEAK TEMPERATURE:     =  63C (146F)     [02-04-18 19:53]
      EROUTE % OCCUP     = 0%
      SOCKET = INACTIVE
      IPLNK STATUS
          A      192.168.210.166    UP         IS-NR
          B      ---------------    DOWN       OOS-MT
      STC IP CONNECTION
          PORT   PST             SST
          A      IS-NR           Active
          B      OOS-MT          Unavail
    Command Completed.
This example shows a full report for an E5-ATM-B card.
    rlghncxa03w 11-03-10 14:00:53 EST  EAGLE5 44.0.0
    1107   134-000-000  LIMATM    ATMHC      IS-NR          Active     -----
      ALARM STATUS       =  *  0022 Clock B for card failed, Clock A normal
      BLMCAP  GPL version = 023-000-000
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CLOCK A             = Active
      CLOCK B             = Fault
      CLOCK I             = Idle
      HS CLOCK A          = Active
      HS CLOCK B          = Fault
      HS CLOCK I          = Idle
      DBD STATUS          = Valid
      DBD TYPE            = ATM
      CURRENT TEMPERATURE   =  54C (130F)
      PEAK TEMPERATURE:     =  55C (131F)     [20-12-22 10:55]
          SLK    PST                LS            CLLI
          A      IS-NR              lsatm11       -----------
          B      IS-NR              lsatm11       -----------
          A1     IS-NR              lsatm12       -----------
                                        MFC         MFC
          SNM     REQ STATUS =   24 hr: ---, 5 min: ---
          SCCP    REQ STATUS =   24 hr: ---, 5 min: ---
          INM     REQ STATUS =   24 hr: G--, 5 min: G--
    Command Completed.
This example shows the output for an E5-ENET-B card used as an IPSM card:
rept-stat-card:loc=1103:mode=full
rlghncxa03w 11-03-09 16:35:57 IST  EAGLE 44.0.0
    1103   134-000-000  IPSM      IPSHC     IS-NR          Active     -----
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CLOCK A             = Active
      CLOCK B             = Idle
      CLOCK I             = Idle
      DBD STATUS          = Valid
      DBD TYPE            = 1G ENET
      PEAK TEMPERATURE:     =  63C (146F)     [02-09-14 14:49]
      SFLOG  = NO
 Command Completed.
This example shows the output for an E5-MCPM-B card:
rept-stat-card:loc=1108
    tekelecstp 11-04-25 19:44:35 EST  EAGLE5 44.0.0
      BLMCAP  GPL version = 134-000-000
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CLOCK A             = Active
      CLOCK B             = Idle
      CLOCK I             = Idle
      DBD STATUS          = Valid
      DBD TYPE            = 1G ENET
      PEAK TEMPERATURE:     =  42C (108F)     [11-04-24 04:32]
      IPLNK STATUS
          A      10.250.37.176      UP         IS-NR
      MCP IP CONNECTION
          PORT   PST             SST
          A      IS-NR           Active
    Command Completed.
This example shows a full report for an E5-MCPM-B card:
rept-stat-card:loc=1108:mode=full
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CLOCK A             = Active
      CLOCK B             = Idle
      CLOCK I             = Idle
      DBD STATUS          = Valid
      DBD TYPE            = 1G ENET
      IPLNK STATUS
      MCP IP CONNECTION
          PORT   PST             SST
          A      IS-NR           Active
    Command Completed.
This example shows the output for an E5-ENET-B card used as an IPSG card:
rept-stat-card:loc=1111:mode=full
stpc9070501 11-05-23 15:30:39 EDT  EAGLE5 44.0.0
    1111   009-003-000  E5ENETB   IPSG       IS-NR          Active     -----
      BLMCAP  GPL version = 009-003-000
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CLOCK A             = Idle
      CLOCK B             = Active
      CLOCK I             = Idle
      DBD STATUS          = Valid
      DBD TYPE            = 1G ENET
      CURRENT TEMPERATURE   =  46C (115F)
      PEAK TEMPERATURE:     =  46C (115F)     [11-05-23 15:09]
          A      OOS-MT             ls1111n00     tklcc1111n0   INACTIVE
          A4     OOS-MT             lr1111n08     tkc1111n8     INACTIVE
      IPLNK STATUS
          A      10.251.105.68      UP         IS-NR
          B      ---------------    ----       ----
      ASSOCIATION STATUS
          ANAME              PST             SST
          egwn1111am3ua      OOS-MT          CONNECTING
          egwns1111a4m3ua    OOS-MT          CONNECTING
                                        TVG    MFC         TVG    MFC
    Command Completed.
This example shows a full report when the EPAP Data Split feature is enabled:
    epap240m 12-01-29 11:53:07 CST  EAGLE 45.0.0
    1201   074-012-005  LIME1    SS7HC      IS-NR          Active     -----
      BPMPL   GPL version = 134-015-000
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CLOCK A             = Idle
      CLOCK B             = Active
      CLOCK I             = Idle
      MOTHER BOARD ID     = MPL
      DBD STATUS          = Valid
      DBD TYPE            = None
      DBD MEMORY SIZE     = 0M
          SLK    PST                LS            CLLI
          A      OOS-MT-DSBLD       lsa1          -----------
                                        TVG    MFC         TVG    MFC
          SCPDN   REQ STATUS =   24 hr:        ---, 5 min:        ---
          SCPIMSI REQ STATUS =   24 hr:        ---, 5 min:        ---
    Command Completed.
This example shows a full report when the Dual ExAP Config feature is enabled:
    1201   074-012-005  LIMDS0    SS7ML      IS-NR          Active     -----
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CLOCK A             = Idle
      CLOCK B             = Active
      CLOCK I             = Idle
      DBD STATUS          = Valid
      DBD TYPE            = None
          SLK    PST                LS            CLLI
                                        TVG    MFC         TVG    MFC
          SCPEPAP REQ STATUS =   24 hr:        ---, 5 min:        ---
          SCPELAP REQ STSTUS =   24 hr:        ---, 5 min:        ---
    Command Completed.
This example shows a full report when both EPAP Data Split feature and Dual ExAP Config features are enabled:
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CLOCK A             = Idle
      CLOCK B             = Active
      CLOCK I             = Idle
      DBD STATUS          = Valid
      DBD TYPE            = None
          SLK    PST                LS            CLLI
                                        TVG    MFC         TVG    MFC
          SCPDN   REQ STATUS =   25 hr:        ---, 5 min:        ---
          SCPIMSI REQ STATUS =   25 hr:        ---, 5 min:        ---
          SEPELAP REQ STATUS =   25 hr:        ---, 5 min:        ---
    Command Completed.
This example shows output for an E5-SM8G-B card running the SIP application:
tekelecstp 12-06-29 15:03:34 EST EAGLE 45.0.0
1205   134-045-000  DSM       SIPHC      IS-NR          Active       -----
  BLIXP   GPL version = 134-045-000
  IMT BUS A           = Conn
  IMT BUS B           = Conn
Command Completed.
This example shows output for an E5-SM8G-B card running the SIP application with mode=full:
rept-stat-card:loc=1101:mode=full
    Command entered at terminal #18.
Command Accepted - Processing
    1101   029-042-007  DSM       SIPHC      IS-NR          Active     -----
      BLIXP   GPL version = 059-042-000
      IMT BUS A           = Conn
      IMT BUS B           = Disc
      CLOCK A             = Active
      CLOCK B             = Fault
      CLOCK I             = Idle
      DBD STATUS          = Valid
      DBD TYPE            = None
      PEAK TEMPERATURE:     =  46C (115F)     [02-13-06 17:11]
      IPLNK STATUS
          A      192.168.120.132    UP         IS-NR
      DSM IP CONNECTION
          PORT   PST             SST
          A      IS-NR           Active
      SIP CONNECTION STATUS
          CNAME         PROT            PST             OPEN
          conn1         TCP             IS-NR           YES
          conn2         UDP             IS-NR           YES
    Command Completed.
This example shows output for an E5-SM8G-B card running the ENUM application:
tekelecstp 14-05-26 15:03:34 EST EAGLE 46.1.0
1205   135-016-000  DSM       ENUMHC     IS-NR          Active       -----
  BLIXP   GPL version = 135-016-000
  IMT BUS A           = Conn
  IMT BUS B           = Conn
Command Completed.
This example shows the output when E5-APP-B cards exist in the system:
rept-stat-card
tekelecstp 12-14-13 11:48:18 EST  46.1.0-0.0.0
rept-stat-card
Command entered at terminal #4.
1105   -----------  E5APPB    EPAP       RSRVD          Avail      -----
1107   -----------  E5APPB    ELAP       RSRVD          Avail      -----
1109   000-000-000  HIPR2     HIPR2      IS-NR          Active     -----
1110   000-000-000  HIPR2     HIPR2      IS-NR          Active     -----
1113   255-255-255  GPSM      EOAM       IS-NR          Active     -----
1115   255-255-255  GPSM      EOAM       IS-NR          Standby    -----
1116   -----------  TDM                  IS-NR          Active     -----
1117   -----------  E5MDAL               IS-NR          Active     -----
6202   -----------  TELCO     SWITCH     RSRVD          Avail      -----
6203   -----------  TELCO     SWITCH     RSRVD          Avail      -----
Command Completed.
This example shows the report for a card location equipped with an E5-APP-B card:
    tekelecstp 12-07-13 11:49:35 EST  45.0.0-64.37.0
    Command Completed.
These examples show the report for E5-APP-B application cards:
    tekelecstp 12-07-13 11:52:44 EST  45.0.0-64.37.0
    Command Completed.
tekelecstp 12-07-13 11:54:41 EST  45.0.0-64.37.0
    Command Completed.
    1103   -----------  E5APPB    LSMS       RSRVD          Avail    -----
    Command Completed.
    1101   -----------  E5APPB    NAS        RSRVD          Avail    -----
    Command Completed.
This example shows the report for a card location equipped with a Telco Switch:
rept-stat-card:loc=6202
tekelecstp 12-09-06 11:43:37 EST 45.0.0
6202   -------      TELCO     SWITCH    RSRVD       Avail     -----
Command Completed.
This example shows the report for Telco Switches with parameter appl=switch:
tekelecstp 12-09-06 11:44:19 EST 45.0.0
6201   -------      TELCO     SWITCH    RSRVD       Avail      ----
Command Completed.
This example shows output for a SLIC card running the DEIRHC GPL:
    tklc1161001 23-02-01 15:31:30 EST  EAGLE 47.1.0.0.0-79.16.0
    Command entered at terminal #2
    1101   001-016-000  SLIC      DEIR64     IS-NR          Active     -----
      BLSLC64 GPL version = 007-014-008
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CURRENT TEMPERATURE =  49C (121F)
      PEAK TEMPERATURE:   =  51C (124F)     [23-02-01 11:11]
    Command Completed.
This example shows output for the DEIR application with mode=full:
    tklc1161001 23-02-01 15:31:38 EST  EAGLE 47.1.0.0.0-79.16.0
    Command entered at terminal #2.
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CLOCK A             = Active
      CLOCK B             = Idle
      CLOCK I             = Idle
      MOTHER BOARD ID     = SLIC
      DBD STATUS          = Valid
      DBD TYPE            = None
      DBD MEMORY SIZE     = 16384M
      HW VERIFICATION CODE= ----
      FPGA VERSION        = 3c8
      BIOS VERSION        = 006
      PSOC VERSION        = 1.0
      Bootloader VERSION  = 2
      IPLNK STATUS
          B      10.254.102.131     UP         IS-NR
          C      ---------------    ----       ----
          D      ---------------    ----       ----
      DEIR CONNECTION STATUS
          DCNAME             STATUS    ANAME              STATUS
          dconn1             DOWN      assoc1             OOS-MT
          dcon2              DOWN      assoc2             OOS-MT
          dcon3              DOWN      assoc3             OOS-MT
          dcon4              DOWN      assoc4             OOS-MT
                                         MFC         MFC
          DEIRSCCP REQ STATUS =   24 hr: ---, 5 min: ---
    Command Completed.
This example shows the full report when an IPS card is provisioned as an SFLOG card:
    tekelecstp 15-05-27 15:43:58 EST  EAGLE 46.3.0
    1107   131-010-000  IPSM      IPSHC      IS-NR          Active     -----
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CLOCK A             = Fault
      CLOCK B             = Active
      CLOCK I             = Idle
      DBD STATUS          = Valid
      DBD TYPE            = 1G ENET
      CURRENT TEMPERATURE   =  45C (113F)
      PEAK TEMPERATURE:     =  45C (113F)     [15-05-27 15:43]
      SFLOG  = YES
      IPLNK STATUS
    Command Completed.
This example shows the full report for an SCCP card with the SFLOG MFC service:
    tekelecstp 15-07-07 07:02:54 EST  EAGLE5 46.3.0
    1101   017-001-013  DSM       SCCPHC     IS-NR          Active     -----
      BLIXP   GPL version = 021-001-000
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CLOCK A             = Active
      CLOCK B             = Idle
      CLOCK I             = Idle
      DBD STATUS          = Valid
      DBD TYPE            = None
      PEAK TEMPERATURE:     =  46C (115F)     [15-07-07 07:02]
      SCCP % OCCUP        = 1%
                                        TVG    MFC         TVG    MFC
          MTP3    REQ STATUS =   24 hr:        G--, 5 min:        ---
          SFLOG   REQ STATUS =   24 hr:        ---, 5 min:        ---
      IPLNK STATUS
      DSM IP CONNECTION
          PORT   PST             SST
          A      OOS-MA          Ueq
          B      OOS-MA          Ueq
    Command Completed.
This example shows output for a SLIC card running the IPSG GPL with mode=full:
rept-stat-card:loc=1203:mode=full
       stpa1090701 16-04-1624 11:09:37 EST  EAGLE5 46.3.0.0.0-68.18.0
    stpa1090701 16-04-16 11:09:37 EST  EAGLE5 46.3.0.0.0-68.18.0
    1203   138-018-000  SLIC      IPSG       IS-NR          Active     -----
      BLSLC32 GPL version = 138-018-000
Idle
Valid
      DBD STATUS          = Valid
      DBD TYPE            = None
39C (103F)
      PEAK TEMPERATURE:     =  43C (110F)     [16-04-12 06:24]
          SLK    PST                LS            CLLI
          A      IS-NR              sd1c114a      -----------
          A1     IS-NR              sd2c114a      -----------
          A2     IS-NR              sd3c114a      -----------
          A3     IS-NR              sd4c114a      -----------
          A4     IS-NR              sd5c114a      -----------
      IPLNK 103.50      UP         IS-NR
          eipa1203am2pa      IS-NR           ESTABLISHED
          eipi1203a1m2pa     IS-NR           ESTABLISHED
          eipis1203a2m2pa    IS-NR           ESTABLISHED
          eipn1203a3m2pa     IS-NR           ESTABLISHED
          eipc1203a4m2pa     IS-NR           ESTABLISHED
                                        MFC         MFC
          SNM     REQ STATUS =   24 hr: G--, 5 min: ---
          INM     REQ STATUS =   24 hr: G--, 5 min: ---
          SCPELAP REQ STATUS =   24 hr: ---, 5 min: ---
rept-stat-card
    tekelecstp 16-05-25 12:38:37 EST  EAGLE 46.4.0.0.0-69.3.1
    rept-stat-card
    Command entered at terminal #3.
    tekelecstp 16-05-25 12:38:38 EST  EAGLE 46.4.0.0.0-69.3.1
    1101   -----------  SLIC      GLSHC      OOS-MT-DSBLD   MEA        -----    1105   139-003-000 TSM       GLSHC      IS-NR          Active     -----
    1106   -----------  SLIC      GLSHC      OOS-MT-DSBLD   MEA        -----
    1109   139-003-000  HIPR2     HIPR2      IS-NR          Active     -----
    1110   139-003-000  HIPR2     HIPR2      IS-NR          Active     -----
    1112   139-003-000  SLIC      IPSG       IS-NR          Active     -----
    1113   030-003-001  E5MCAP    OAMHC      IS-NR          Active     -----
    1115   030-003-001  E5MCAP    OAMHC      IS-NR          Standby    -----
    Command Completed.
This example shows output for a SLIC card running the ENUMHC GPL with mode=full:
    tekelecstp 16-06-22 03:19:34 EST EAGLE 46.4.0.0.0-69.3.1
    1103   139-002-000  SLIC      ENUMHC     IS-NR          Active     -----
      BLSLC32 GPL version = 139-002-000
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CLOCK A             = Active
      CLOCK B             = Idle
      CLOCK I             = Idle
      DBD STATUS          = Valid
      DBD TYPE            = None
      PEAK TEMPERATURE:     =  73C (164F)     [16-06-22 00:30]
      IPLNK STATUS
          B      10.248.13.81       UP         IS-NR
      DSM IP CONNECTION
          PORT   PST             SST
          A      IS-NR           Active
      ENUM CONNECTION STATUS
          CNAME         PROT            PST             OPEN
          conn1         UDP             IS-NR           YES
    Command Completed.
This example shows output for a SLIC card running the SIPHC GPL with mode=full:
tekelecstp 16-06-21 02:40:34 EST EAGLE 46.4.0.0.0-69.3.1
    rept-stat-card:loc=1101:mode=fullentered at terminal #18.
    1101   139-002-000  SLIC       SIPHC      IS-NR          Active     -----
SLIC
None
      PEAK TEMPERATURE:     =  73C (164F)     [16-06-21 02:40]
      IPLNK STATUS
          A      192.168.120.131    UP         IS-NR
          B      10.248.13.76       UP         IS-NR
      DSM IP CONNECTION
          A      IS-NR           Active
This example shows output for a SLIC card running the ERTHC GPL with mode=full:
rept-stat-card:mode=full:loc=1107
    tekelecstp 16-07-14 05:52:22 EST  EAGLE 46.4.0.0.0-69.3.1
    1107   139-002-000  SLIC      ERTHC      IS-NR          Active     -----
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CLOCK A             = Active
      CLOCK B             = Idle
      CLOCK I             = Idle
      DBD STATUS          = Valid
      DBD TYPE            = None
      PEAK TEMPERATURE:     =  73C (164F)     [16-07-14 05:50]
      EROUTE % OCCUP     = 0%
      IPLNK STATUS
      STC IP CONNECTION
          PORT   PST             SST
          A      OOS-MT          Unavail
          B      OOS-MT          Unavail
    Command Completed.
Command Executed
This example shows output for a SLIC card running the MCPHC GPL with mode=full:
    tekelecstp 16-07-14 06:09:15 EST  EAGLE 46.4.0.0.0-69.3.1
    1107   139-002-000  SLIC      MCPHC      IS-NR         Active    -----
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CLOCK A             = Active
      CLOCK B             = Idle
      CLOCK I             = Idle
      DBD STATUS          = Valid
      DBD TYPE            = None
      PEAK TEMPERATURE:     =  74C (166F)     [16-07-14 06:06]
      IPLNK STATUS
          A      10.248.13.93       ACTIVE     IS-NR      MCP IP CONNECTION
          PORT   PST             SST
          A      OOS-MT          Unavail
    Command Completed.
Command Executed
This example shows output for a SLIC card running the SCCPHC GPL with mode=full:
    tekelecstp 16-07-14 06:37:51 EST  EAGLE 46.4.0.0.0-69.3.1
    1107   139-002-000  SLIC      SCCPHC     IS-NR          Active     -----
      IMT BUS A           = Conn
      IMT BUS B           = Conn
      CLOCK A             = Active
      CLOCK B             = Idle
      CLOCK I             = Idle
      DBD STATUS          = Valid
      DBD TYPE            = None
      CURRENT TEMPERATURE   =  72C (162F)
      PEAK TEMPERATURE:     =  73C (164F)     [16-07-14 06:24]
      SCCP % OCCUP        = 0%
                                        MFC         MFC
          INM     REQ STATUS =   24 hr: ---, 5 min: ---
      IPLNK STATUS
      DSM IP CONNECTION
          PORT   PST             SST
          A      OOS-MA          Ueq
          B      OOS-MA          Ueq
    Command Completed.
Command Executed
Legend
  • CARD—Location of the card
  • VERSION—Version number of the application loaded on the card. Dashes (- - - - -) in the version column indicate one of the following conditions about the card:
    • The card is configured but is not physically present in the system.
    • The card does not run a GPL, such as TDM or MDAL cards.
    • The card is IS-ANR or is in the process of being loaded.
  • TYPE—Card type entered in the database.
  • APPL—Application loaded on the card
  • PST—Primary state of the card. See  Possible Values for PST/SST/AST .
  • SST—Secondary state of the card. See Possible Values for PST/SST/AST .
  • AST—Associated state of the card. See Possible Values for PST/SST/AST .
Message Flow Control status is displayed in these fields: SNM REQ STATUS (SNM messages), SCCP REQ STATUS (SCCP messages), EROUTE REQ STATUS (EROUTE messages), INM REQ STATUS (INM messages), MTP3 REQ STATUS (MTP3 messages), and SFLOG REQ STATUS.
For card type STC (EROUTE application), the MFC status is not displayed.
Message Flow Control status output is displayed as a series of these letters:
  • G—MFC found a service with available capacity. Indicates normal system behavior.
  • D—Servers were present in the system, but no server had available capacity. Indicates an overload, but MFC is working correctly.
  • N—No operational server cards were available in the system for use by this card over the corresponding interval.
The HW VERIFICATION CODE field is shown only in the mode=full report. ----- is shown in the HW VERIFICATION CODE field for cards with valid hardware detected. One of the following numerical values is shown when invalid hardware is detected, and all such cards will be auto-inhibited.
* It is possible that the card will continually boot in these cases, before the alarm is ever displayed.
Table 4-51 Auto-Inhibit Hardware Verification Codes
HW Verification Code Card or Application Code Description Associated UAM Code
058
SS7IPGW, IPGWI, IPLIMI
E5-ENET-B does not support > 16 associations (IPLIMx).
E5-ENET-B does not support > 50 associations (IPGWx).
422
059
VSCCP
MPS database has been detected to exceed capacity of Service Module extended memory (only for GPORT, GFLEX, INP, EIR features). UAMs 281, 283, and 285 are used for LNP and LNP ELAP Configuration features.
422
090
Various
Flash image on the card is incompatible with the current release of the EAGLE
570
099
E5-TSM
E5-TSM card equipped has one or more daughterboard.
99
102*
SS7IPGW, IPGWI
Non-DCM detected in slot.
99
103
E5-ENET-B does not support >16 associations (IPLIMx).
E5-ENET-B does not support >50 associations (IPGWx).
276
103
IPSG
E5-ENET-B does not support >32 associations (IPSG).
276
104
SS7IPGW, IPGWI,
E5-ENET-B does not support >0 sockets (IPLIMx).
E5-ENET-B does not support >0 sockets (IPGWx).
276
105
E5-ENET-B does not support > 0 (sockets + associations) (IPLIMx).
E5-ENET-B does not support > 50 (sockets + associations) (IPGWx).
276
106
E5-ENET-B does not support >3200Kb SCTP buffers (IPLIMx).
E5-ENET-B does not support >3200Kb SCTP buffers (IPGWx).
276
132
IPLIMI
The actual card in the slot must be a high capacity MIM or LIME1 if card is provisioned as a LIME1 card.
99
136
E5-ATM-B
E5-ATM-B is provisioned
297
140
MCPHC
MCP card not running with D2G memory
422
141
IPS
E5-IPSM card not running with D2G memory.
422
142
MCP
E5-MCPM-B card not running with D4G memory.
422
150
various
Card is obsolete.
47
165
VSCCP
Hardware configuration does not support configured feature set.
99
170
EROUTE
Non-E5-ENET-B card detected in slot provisioned for eroute with card type STC.
99
172
IPSG
Non-SLIC card detected in slot provisioned for IPSG and card type is SLIC with data=gtt.
99
174
IPSG
SLIC hardware detected having 32-bit flash GPL (BLSLC32) in a slot provisioned for IPSG and card type is SLIC with data=gtt.
99
179
E5-ATM-B, E5-ENET-B, E5-E1T1-B
EPM-B based card detected and MFC is OFF.
99
180
SCCP, SS7ANSI
SCCP card equipped with DCM with MOBR on.
441
DEIR, ENUM, SIP
If ports C and D are configured, the card location must be populated with SLIC cards only.
